Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Forum Announcments/FAQ/Suggestions/Test > Website Announcements
0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
Last Post: Skeezix
0 5 gal tank
0 Speed
0 1200 conversion
Last Post: Magneto Sportster
0 opinion time (bike broke again)
Last Post: Skeezix
Last Post: r100steve
0 testing wiring harness connections
0 2011 1200C tuner?
Last Post: tussuck
0 Timing
Last Post: ezmerf
0 Mild 1250 build thoughts?
Closed Thread
Old 10th July 2012
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Ladies and Gents, while readily available, they can not be posted here on the forum...it puts Bert in a very precarious position, to the point of shutting the whole thing down...now would you be wont of that?
Old 10th July 2012
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
Unlike other manufacturers Harley's hard copy manuals are reasonably priced. Same for aftermarket manuals. One additional source might be your local public library. Mine has a pretty fair inventory of manuals and the Liberian was open to getting additional models and years. She preferred to get Clymers as they tend to cover more years per manual. Certainly a good source for casual tune ups and general maintenance.
SEMJPM
Old 10th July 2012
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
I was involved in a project while I was at SGI working with HD. They wanted to put all their manuals online with great detail. You could basically drill down to each component and then sub component until you went from a birds eye view of the bike all the way down to the specific part like a wrist pin (kind of like google maps for a harley). Clicking on the part would pull up all information including part numbers and availability. The next step in the project was assembly/dis-assembly. Right clicking on an assembly would bring up a menu and you could select "remove or install" and you would see an animation of how to remove or install a specific part or assembly.
I will check on what happened to it, but last I remembered, none of the dealers wanted it so the project got canned.
One of the large boat manufacturers has the same thing. Click on the engine and watch while it disassembles itself. Pretty cool stuff and at the time it was 3D (using glasses and specific monitor).
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
Old 25th April 2016
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Not knowing this when I first joined. Thanks for letting me know. Now that I know. My bad.
I will look for my post and edit it accordingly.
Edit: I see a mod already did the edit already. Sorry for being a PITA. I won't make the same mistake again.
Old 18th May 2016
DylanBoe DylanBoe is offline
Sportster/Buell Model #2: 883 standard
Other Motorcycle Model: 1200v(wrecked)
DylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of lightDylanBoe is a glorious beacon of light
If you search around, you might find some of the manuals on clearance, from a dealer. I got all three of the manuals for my '12 "V" about half price each, which can't be beat. Of course in Houston, Tx there are plenty of dealers here to choose from.
Old 18th May 2016
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
I have the FSM, Clymers and the pdf.
Wish I had the FSM in pdf format. I don't have time often to wash my hands when looking something up
It's Hammer time
Old 18th May 2016
Ranchero50's Avatar
Ranchero50 Ranchero50 is offline
Sportster/Buell Model: 1200 Street Brawler
Ranchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond repute
I will only add that the PDF manual I have is 44 meg and stays on a USB stick so it can travel with me. It also has quick links in the PDF to open the correct sections.
The build thread... http://xlforum.net/forums/showthread.php?t=1821880
Old 18th May 2016
Scar55 Scar55 is offline
Sportster/Buell Model: 1981 xlch
Sportster/Buell Year: 1981
Other Motorcycle Model: Night Train
Other Motorcycle Year: 2007
Scar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud ofScar55 has much to be proud of
I have mine on a cd that I bought on eBay. When I rebuilt my forks, I just printed out the pages I needed. I put them in clear sleeves and put them in a folder.
Kelly
Old 18th May 2016
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Let's remember what this thread is about. It is about NOT sharing links to bootleg copies of any HD service manual. HD is very protective of its copyrights and to share illegal copies of them is a crime.
AMA #961454
Old 21st May 2016
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
What does it cost to buy a manual?? The same price as a tank of fuel!!!!
All of my bikes has their own manual. And when I sell the bike I hand over the manual to the new owner.
Closed Thread
