Last Post: Andy56
0 MS rollers way too tight
Last Post: Rolli
Last Post: PappaBravo
Last Post: ronccc
0 Newbie
Last Post: BitterOldMan
0 KBS tank sealer
Last Post: jcro61
0 OEM Headlight Bucket?
Last Post: Mission1
0 Tools
Last Post: 84rzv500r
0 my sunday driver...
0 -65A mufflers
0 my daily driver
Last Post: webman94
0 Now running 3.40 factory gearing
0 carbs?
0 Better Brakes
0 just for my head
Last Post: Iron Chuck
0 2020 End of Year Report
0 81 parts
Last Post: kobra50
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: exexpat93
0 Grateful Dead Timing Cover Source?
Last Post: rocketnorton
0 Brake light issues
Last Post: 45Brit
adjustment, backfires, engine, problem, valves
Old 25th April 2014
Miokoukou Miokoukou is offline
Miokoukou is an unknown quantity at this point
Today i call all the sporster quyz in my island for coffee to my home so i check all the bikes by wire off the spake plug wire all except the injection one Iron. Works same with me when wire off the front spark plug wire engine turn off and when wire off the rear plug keep idling so i am crazy after all or not ?????????? Should be an engine work like this???? Or we need an engineer for harley's in greece immediately??
Old 25th April 2014
sportytrash's Avatar
sportytrash sportytrash is offline
Sportster/Buell Year: 93
Other Motorcycle Model: '72 Bonnie
sportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to behold
Originally Posted by Miokoukou View Post
I have buy the sporster working like this with oem factory no sound mufflers. When i took it to the only one engineer in my island that fixing harley said that is ok. My sporster works from the day i buy it like this. I buy it in 2010 with 6.700km only model 1996. So i buy it like new from the factory in other words.I don't have any symptons but only some Backfires by the day i bought it. First i check carb so the membrane accelerator was broken cause of the 14 years that the bike was without working. Less backfires but not No backfires.Then i change the manifold o-rings 3 of them nothing happend so the backfires keep doing it 4 years without stop but it's only few in many km so i don't care. It's the only sympton i have if it's usefull.
Perhaps new diaphragm tore upon installation ? 3 O-rings ?? Or 2 O-rings and a gasket for Carb to intake ?
"The mid-sixties XlCH is to motorcycling what a hooker's come on is to romance: crude, rude and unmistakable". Jim Miller Cycle Guide Dec. '84
Defender of the faith
Powerhouse drifter
Old 25th April 2014
Though rare new parts can be defective. Put rear plug wire on front cylinder and see what happens.
Old 25th April 2014
Already done works the same. Rear cylinder keep not perfect.And front work perfect.
Old 25th April 2014
2 o rings 1 gasket.
Old 25th April 2014
Was asking what front cylinder did with rear plug wire on it.
Old 26th April 2014
Work perfect.Like always.
Old 26th April 2014
MikeOK's Avatar
MikeOK MikeOK is offline
MikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really nice
It ran with the rear coil wire on the front cylinder? No way man
Old 26th April 2014
stonierides stonierides is offline
stonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the roughstonierides is a jewel in the rough
you have a bad coil dude. their is a way to check a coil. .5 ohms is the max limit, I think. need a multi meter to check if the coil is in tolerance. sure u did it with boat motors. if one cylinder is running ok, the other one is getting fuel unless you left a rag in the intake manifold. simple elimination of trouble. air, fuel, spark. that's all it takes.
Old 26th April 2014
JackAttack's Avatar
JackAttack JackAttack is offline
JackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant futureJackAttack has a brilliant future
I switched the coil wires on my bike on accident once and the bike wouldn't even start. I have to agree with Mike here.
The universe is shaped exactly like the earth..if you go straight along enough you'll end up where you were.
