Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 What weight oil?
0 Powerraythor conversion
Last Post: class of 82
0 blonde, brunette, red?
Last Post: Lincoln
Last Post: SLW210
Last Post: wrkdWS6
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
0 P0505 code on my '09 XL883C driving me insane!!
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
0 Timing
Last Post: Skeezix
Old 3rd August 2016
sportbikeco sportbikeco is offline
Sportster/Buell Model: m2
Sportster/Buell Year: 00
sportbikeco is an unknown quantity at this point
Default Sportster transmission in buell?
Can I swap a sportster transmission into my 2000 Buell M2? Are the ratios the same?
Could I leave the 5th gear in place attached to the shaft with the drive pulley and swap out the trans attached to the trap door only or is that gear cut different on sportster?
Replacing on lower millage (16k) bike due to 1-2 shift issue, shift fork 1-2 shot, dogs messed up. Shifted great 3->5.
