0 Sifton cams on stock 74 XLCH
0 Better Brakes
Last Post: Sasnak75
0 Opinions on Mallory unilite ignition
Last Post: mikethebike61
0 Hydrostatic fuel gauge
0 Chasing a generator noise
Last Post: randy3934
Last Post: oldboy
0 S&s
0 Installing jugs finally but another Q
0 Li/Ion battery in '03
Last Post: Eric Von Zipper
0 Late-model stator on rigid-mount bike?
Last Post: Curbside
Last Post: 83XLX
0 1968 ex barn dweller thread
0 my sunday driver...
Last Post: 84rzv500r
0 Microsquirt?
Last Post: Curbside
7 Ironhead yes or no
Last Post: exexpat93
Last Post: iBloke
0 fork oil change with Ricor intiminators
wlm (57), Greg81XLH (55), saylor01 (54), Alicia (52), latnyte (51), antonini (43)
adjustment, broken, clutch, gears, slipping
Old 15th May 2017
goofyfoot2001's Avatar
goofyfoot2001 goofyfoot2001 is offline
Sportster/Buell Model: 1200
Other Motorcycle Model: Vulcan 750
Other Motorcycle Year: 1995
goofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nicegoofyfoot2001 is just really nice
One of the employees at the bike shop I use had this happen as well. It does sound like the culprit.
Also, check your belt and make sure it still has it's teeth. I also have a friend who had all the teeth strip off the belt.
That was correct :-)
Old 15th May 2017
StickFSMC's Avatar
StickFSMC StickFSMC is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1998
Other Motorcycle Model: FLTRU
StickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant futureStickFSMC has a brilliant future
I'm glad you got it solved. Not too expensive either I hope.
StickFSMC: USAF 1980-84:
1998 XLH 883
1962 XLCH Ironhead
2012 FLTRU RoadGlide 110"
Old 15th May 2017
He mentioned two problems - which was it? The teeth of the pulley or the teeth of the belt were missing?
IXL 2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
An XLForum collection of technical info & advice
