Last Post: koolbreeze
0 Head Porting 101
0 at least RDRS
Last Post: RDHenley
Last Post: ZCarFan
0 Powerraythor conversion
Last Post: RDHenley
0 BETTER Brakes for $214
0 roadside belt change
0 Blackstone HyperTek
0 [Ignition}Points in a 2000n evo
Last Post: lostjohnny
0 tubing strength if pressed?
Last Post: JonesL
0 Request for recommendations: Sissy Bar for chopped fender
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 super b overflow
0 69 oil pump breather timing mark
0 is a buell a harley
Last Post: Coz
  #191
Old 11th October 2019
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Originally Posted by spamer80 View Post
I don't actually want it to be faster)
......said no one, ever.....
Old 12th October 2019
spamer80 spamer80 is offline
Sportster/Buell Model: XLX1000-61
spamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nicespamer80 is just really nice
Today's progress: doing some clean wire harness work. Stopped on the idiot lights (gen, oil). Both refuse to work properly when wired. Actually refuse to go on at all. There is LEDs.
Am I wrong, or what?
Gen light should be A from gen -> light -> ignition (coil +12 in my case).
Oil light should be sensor -> light -> ignition (coil again in my case).
There is definetely current on coil (just ignition turned on and killswitch is off). And engine is working properly if I press start.
Old 13th October 2019
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
touch ur forefinger ..too ur fore head .. while sit on the bike,,,,
You forgot that I need to drink some booze while doing it
The first ring that something is wrong with my setup should'e appeared in your head when I installed the automatic clutch
Howver, smooth not always means slow
Old 4 Weeks Ago
Progress for today: adjusted the clutch perfectly, the start and shifting is smooth, neutral is easy to find. Now carb. 42/180 currently and very hard to start. I'm thinking to start from 45.
Can't deal with front brake switch, turn signals and gen lamp. They all working like assholes, all the wires are in perfect connection, seems like I'm doing/understanding it wrong.
Will ask friend for help. Everything else is working as it should.
Old 4 Weeks Ago
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I have a 23/49 combo on my '83 XLX and it's geared a little too high. I'll probably go back to the 48 rear and put a 22 up front. I have a regular heavy-duty chain, not an o-ring chain, and I still had to grind a little off the sprocket cover bosses for clearance.
With the 23/49 sprockets and a 90 profile rear tire, 70 mph is about 3400 rpm. Nice on the highway, but the big gap between 3rd and 4th gears became more pronounced and the bike doesn't like going up mountains at legal speeds in 4th gear.
Old 4 Weeks Ago
I have c-ratio andrews gears, so probably no big gap. Also, my city is as flat as some girls chest, so no mountains. Currently 23/48.
Old 4 Weeks Ago
doodah man's Avatar
...but the big gap between 3rd and 4th gears became more pronounced...
Not enough can be said about that ‘c’ ratio! Eliminate the gap!! You’ll never know how you got along without it.
Old 4 Weeks Ago
Kind of upgraded the clutch outer plate. With this square 3/4 hole I'll be able to rotate the crankshaft with any available wrench through the clutch inspection window. I thought about hex wrench or 1/2 socket but 1/2 was too big for inspection window and hex is a little short.
The reason I make this, is to be able to adjust pushrods and set ignition timing. And everything else where I need to rotate the flywheel.
Initially I've lost the ability to do this because the clutch is disengaged by default. And now I don't need to remove primary cover or even need to lift the rear wheel ever again. Perfect.
