0 Hydrostatic fuel gauge
Last Post: Andy Hog
Last Post: Desertfox
0 Fork Brace worth the bucks???
Last Post: exexpat93
Last Post: 83XLX
0 Installing jugs finally but another Q
0 1968 ex barn dweller thread
0 Sifton cams on stock 74 XLCH
0 Opinions on Mallory unilite ignition
Last Post: Heff
0 my sunday driver...
0 Microsquirt?
Last Post: Curbside
0 S&s
0 Better Brakes
7 Ironhead yes or no
Last Post: iBloke
0 fork oil change with Ricor intiminators
0 Li/Ion battery in '03
0 Tools
Last Post: denguy
0 18” rear wheel mag
Last Post: Yourstrulythom
wlm (57), Greg81XLH (55), saylor01 (54), Alicia (52), latnyte (51), antonini (43)
Old 9th November 2019
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Default Choke
Choke or Fuel enricher ,
on my bike when you pull it out it will not stay in place,
should should it have stops so that it stays in place sort of half way out ??
I have to hold it out when starting
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
There is a nut, on the cable housing, on the back side of the bracket where the knob is. Tighten the nut a little bit.
bustert bustert is online now
common issue
sometimes it just needs to be replace, been there done that.
BKB's Avatar
BKB BKB is offline
Or you can just clip a wooden, spring clothes line clip on it, as I did on my '04. It's just wide enough to hold it open. Clip it on the clutch cable when you're not using it.
Air-cooled Forever
Cleaning any oils and dirt off the choke knob shaft and assembly helps, then tighten the knurled wheel behind the knob while holding the nut on the back of the bracket. (Never oil this cable)
60Gunner's Avatar
60Gunner 60Gunner is offline
Be careful not to overtighten tho. It's plastic and will break. Tighten a little at a time. Just enough til it holds where you set it but pushes in easy too.
Old 10th November 2019
Here's the section in the Sportsterpedia regarding the Enrichener Knob Function & Adjustment:
http://sportsterpedia.com/doku.php/t...function_choke
