Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
0 Stock 02 883 FS
Last Post: Jvb13
0 Repainted my bike
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: Doc308
0 Magneto points & condenser
Last Post: Nitro57xl
0 The Sport(ster)ing Life
0 Xl???
0 Now I did it. Feel my pain
0 Hi everyone
0 Hello from LA area
Last Post: webman94
0 Morning default to odometer
0 Your never too old
Last Post: ss396
0 Tuners
Last Post: Zoo
0 DUAUL DISK SPRINGER? Experts Help
Last Post: Samedward
0 Ulysses Oil Fittings?
0 AHDRA Orlando speed world??
Last Post: painterdude923
0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
Closed Thread
Old 16th June 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
Default Correction: 2004+ XL Oil Capacity 2.8 qts
H-D has finally figured out that the 2004+ XL oil capacity is not 3.6 qts as listed in the service and owner's manuals, but is actually 2.8 qts. They issued a tech tip (#312) for the dealers on 6/15/07. (thank you to the dealer who faxed this to me.)
2004-2007 Sportster Oil Capacity
Service literature for 2004-2007 XL models incorrectly lists oil capacity as 3.6 quarts (3.4 liters).
The correct amount listed should be 2.8 quarts (2.65 liters).
Oil capacities listed are approximately the amount required to bring the fluid level near the full mark on the dipstick. Refer to the applicable service manual for the complete oil change procedure.
Service Note:
Be aware that the dipstick has a Full mark to indicate the highest level of oil that should be installed in a hot engine and an Add mark to indicate the lowest level of oil in a cold engine. The engine is designed to operate correctly with the oil level in the range between these two marks. While it is most important to not overfill the system, it is acceptable to operate the motorcycle with the oil level anywhere in the range between the Full and Add marks.
--Chris
Old 16th June 2007
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
So, um ...hmmm. What of oil consuption threads? everybody must drain oil and refill. Sounds like some engines could be way overfilled
Old 16th June 2007
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
Thanks Chris. FINALLY!! They have gotten around to publishing the correct data. It only took them what...... four years?
2005 XL1200C
Those who trade liberty for security have neither.
Old 16th June 2007
chrishajer's Avatar
Yeah, they must have been get the 2008 info ready and came across this error.
--Chris
Old 16th June 2007
smackie's Avatar
smackie smackie is offline
Sportster/Buell Model: Sportster XL1430R
Sportster/Buell Model #2: Yammy-Ha wr250x
Sportster/Buell Year #2: 2010
Other Motorcycle Model: Kawi-socky KX450F
Other Motorcycle Year: 2009
smackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to allsmackie is a name known to all
no chit?
my be part of the probem with all these other issues
2005 XL1200R "The Road Runner"-NRHS Stage 3 heads 88 kit Mikuni 45 SE 575 RB 2-1 pipe tc88a w/custom map Hurricane 3" intake RB AFR Gauge Progressive Front/rear springs/shocks fork brace intiminators metzlers hurricane oil filter steel brake lines golan petcock badlander seat.... the "Death trap" custom is being built
Old 16th June 2007
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
(Correction 2004+ oil cap. 2.8 qts.)I think its a bunch of b.s. I've been putting in every bit of 3 and 1/2 qts as full as i can get it for over 20,000 miles on my '05 883 and never had any problems. It just don't make sense to say h-d engineers all of the sudden remember what the oil capacity should be? Or to change it to suit their new problems. I might be missing something but it just don't pass the smell taste. There's too much in the '04 and up oil thread for me to keep up with but what I've read i just don't know. Whats the deal? It really looks like nobody knows for sure. The only thing i know for sure is its smelling bad. This can't be too good and can make sells drop like a rock when more people get wind of these problems. The main reason i bought a 883 was it was affordable at the time and i thought i could convert it to 1200cc simple and easy. So much for that crap.
Old 16th June 2007
Crusin_w00kie's Avatar
Crusin_w00kie Crusin_w00kie is offline
Sportster/Buell Model: FLSTN
Crusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of lightCrusin_w00kie is a glorious beacon of light
HA!!! I was right when I did my oil change. I knew I wasn't seeing things!!
1990 Mazda B2200 (with no body or frame rot...imagine that!!)
Toy=07 xl1200R (taxes paid and re-flashed)now with FUELPAK! (Sold August 2010) gone but not forgotten.
*new* 2010 Deluxe - Big sucker - PC5 - V&H true duals (much more)
Old 16th June 2007
rikrak's Avatar
rikrak rikrak is offline
Sportster/Buell Model: 883XL
Other Motorcycle Model: "Scooter" CH250 Elite
Other Motorcycle Year: 1985
rikrak has disabled reputation
Cool Did Harley Just Put The Dip in Dip-Stick
Interesting, however, I use the over-sized filter and then just put in 4 quarts. That is what I've done each oil change (4) seems to fill the oil tank to the proper mark on the dip stick and I've never had any issues or problems with my 883XL
rICK
186,000 Miles Per Second, It's Not Just A Good Idea, It's The Law---Eschew Obfuscation!
Old 16th June 2007
chrishajer's Avatar
You can really get 3-1/2 qts in there? That's amazing. It's the first time I can remember someone saying that.
I wasn't relating this to the oil usage thread at all. I thought it was a well known fact that the bikes don't hold anywhere near what the manual says, and most people end up putting about 3 qts into the system total. I just figured HD was saying it officially. Well, the fax LOOKED official. Maybe it was a scam or someone playing a joke on me. Any dealers who can confirm the tech tip?
--Chris
Old 16th June 2007
Roadster_Rider's Avatar
Roadster_Rider Roadster_Rider is offline
Other Motorcycle Model: Victory High-Ball
Roadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura about
Wow, they could have asked any of us for that one...
Cory
Closed Thread
