0 Cases Full Of Oil
Last Post: shopteach
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
0 Loose oil pump feed fitting - 2019 Iron
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
Last Post: kobra50
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
Last Post: Bow only
0 Speed
0 gas cap
0 Buy A new battery
Last Post: denguy
5 What year is the most collectible Sportster.
Last Post: denguy
14 TC 88A Chat
Last Post: BWP 5p
0 sportster and a grand
0 Anyone hunting an XLCH in a Norton Featherbed Project?
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Old 29th March 2010
Hogwylde's Avatar
Hogwylde Hogwylde is offline
Sportster/Buell Model: 883-1200 Custom
Hogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond reputeHogwylde has a reputation beyond repute
Default oil question
Is it ok to add dino oil to break in oil if the levels are low? Is there really anything special about break in oil compared to dino?
The mind is like a parachute. Works best when open.
Old 29th March 2010
rocketmangb's Avatar
I suppose it depends on what you call "Break In Oil"
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 29th March 2010
Hogwylde's Avatar
It's probably just BS but I am referring to the oil that was in my car when I bought it new. Supposedly the properties are different from regular dino or synthetic oil and is specifically used to beak in the engine until it gets its first oil change.
But I can't see the harm in adding the recommended oil to it. Was just curious.
Old 29th March 2010
Default Break in oil
In this day and age of roller tappets and close tolerences with rings that are lapped before the engine is assembled,variable valve timing and CAFE issues not to mention the emissions equipment problems i really dont believe there is such a thing as break in oil.
Oh sure,several companies make such a thing but its really for race and hot street motors that need high doses of ZDDP or zinc something or other whatever the hell its called
Othewise any SM rated oil in the correct weight per the MFG should be fine.
Old 29th March 2010
option12's Avatar
option12 option12 is offline
Sportster/Buell Model: XLC1200 w/phase 1
option12 is an unknown quantity at this point
if its new and the levels are low, seems like time to talk to the dealer.
