0 New to 2002 hugger 883
0 New member
Last Post: Ben2414
0 Talking dog
Last Post: Bow only
Last Post: staniel
Last Post: Hillbilly Angel
Last Post: xlerate
0 F/S 01 Sportster 883, semi cafe style
Last Post: Truckedup
0 XR1000 streettracker project
Last Post: Scott
Last Post: Reverend G
0 Pictures that need no explanation... don't let this thread die!!
Last Post: 4schizzle
0 1999 Buell X1 Part out
0 handlebars
Last Post: motorend
0 Wet Sump Ifo, fix and tools
Last Post: smokey 2
0 A Day in the Life...
0 XLCH Crazy voltage spike
Dead Henry (72), iustabfast (65), dcinpa (63), jwursta (63), G-TIFF (61), TexasHarley (61), CROW (59), Darrell (58), dotom, H34TH3N (57), TessArooo, unitedcycles (21)
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Default Ultima elec ign 40 degree timing
If my Ultima was programmed for kickstart...6200 rpm and 40 degree advance....what does the 40 degree advance do w the timing? How or do I manipulate anything to get my 45
most electronic ign will revert to base or zero degrees when shut down, this is a must for a manual foot. the 5 degrees will not matter much and can actually help with bad fuel. but if you insist, you can advance the module 5 degrees by using a dial back timing light.
that said, maybe it will and maybe it won't, could add a potential of kick back, not a good thing with a manual foot.
Nitro57xl Nitro57xl is offline
Nitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really nice
Just time it with the Tdc mark at the rear of the timing hole and that will get you pretty close to 45 degrees advance. Or use the rear piston, when it's at the top you are at 45 degrees before Tdc on the front.
mickey t's Avatar
Yes uaed the single dot n set it at the back of hole n got it to fire on 3rd kick....nrfore that I went off the vert line then double dots which gave me crazy kick back...saw a diagram for early sportster timing n it shiwed the singke dot at rear of window n thats the best it's neen so far so that is def the answer
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1983
I, can help u , I run the same,, give me a call ,, 770 739 6349,, I,ll be up to 2.00 am est
mickey t's Avatar
I'll be home in Half hour from work...I will def call...thanks brother
Sportster/Buell Year: 1974
This is true. Good advice for static timing the ultima using the TDC mark and adding 5° to the programmed full advance setting.
This is true too, but it's not the right crank position for timing the ultima. Good for static timing with points on a 900 though.
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
screw all this timing marks and do thid do that.i absolutely told you how to set it and adjust the timeing from there.lay it down at the front of the module,retard,bring it up in top,advance.you sure as shit don't need to listen to all the bs.it fired good when you set it up like I told you.damn it keep on with what I told you.i went thru all this 6 years ago when I set up my first one years ago and 50000 miles ago on my stroker.oh well go ahead and beat your head against the wall.make sure its set for single fire.adios
mickey t's Avatar
I got it set like ya said brother....fires nice...took it for a run around town today....battery is low now...probably from all the kicking from the beginning...got it on a charger tonight
SHAKY DAVE's Avatar
rock and roll brother.sorry for all the mind f's you been getting.keep it simple is words to live by
