Last Post: Bone
0 Spokes or Mags
Last Post: SLW210
0 White Letter Tires
Last Post: jharback
0 Got New Bike - 2002 Sportster Project
Last Post: jharback
Last Post: Sprtstr1200s
Last Post: webman94
0 Changing Secondary Gear Ratios on 1250 Conversion
Last Post: jcmellis
0 Led upgrade 1200S
Last Post: NZstu
0 Loose/Sloppy Shifting
Last Post: GT Cyclery
0 Installing Brembo Goldline brakes on a 1998 XLH1200
Last Post: Big Al
0 very hard pull after Billet hydroclutch install
0 Who's still riding???
0 How stock is your bike
Last Post: Beelzeboss
Last Post: jcn59
0 What are some sellers thinking?
Last Post: Knuckles
Last Post: JonesL
0 Screw Loose's Repairs
0 Unapproved Threads And Posts
Last Post: bplinson
0 cancer
Last Post: lynnx
0 Seat Poll - Bad Ass or Fat Ass
Last Post: khav
0 Cracked exhaust bracket short shots
Last Post: Screw Loose Dan
0 Howdy from Baytown, TX
BlackAce BlackAce is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1981
BlackAce is an unknown quantity at this point
Default Replacing Front brake switch
Apologize if this is a repost but can’t seem to find any info on this.
I’m trying to replace my front brake switch inside the master cylinder on my 81 XLH. From my understanding its supposed to unscrew when I try to unscrew it just spins with the metal cylinder that’s it is incased in. Tried holding it with needle nose pliers but that doesn’t work.
Factory service manual I have states to disconnect wires and discard switch. Replace switch as a unit. Obviously this is easy but I’m having a hard time. I don’t want to break the metal cylinder if I need it.
rokytnji's Avatar
rokytnji rokytnji is online now
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
My next step would be disconnect the brake line and mirror and work on it on my bench.
Traveled to
Everything is already disconnected and apart. I have to rebuild the master cylinder.
rokytnji's Avatar
The switch then should be easy to see what the hang up is on your end . With good lighting and a keen eye.
You are right on track . It should just unscrew.
rokytnji's Avatar
I just went outside to the shop and took a pic of my 1980 switch pulled .
that
If that helps.
