0 Your never too old
0 Tuners
Last Post: Sirrom1
0 Morning default to odometer
Last Post: Eric Von Zipper
0 Sportsters in movies and TV
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
Last Post: ronccc
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
Last Post: Zoo
0 E85
0 Sportster drag bike
Last Post: Zip1
0 Cosmo's ECM Relocation Mod
0 Throttle side turn signal failure
Last Post: OntarioIron
Last Post: 1200CustomHD
Old 18th July 2016
sportsterdoc's Avatar
Default 2007-2009 electrical glitches
Several 2007-2009 owners have posted regarding hiccups, which are likely electrical. Whatever the main cause, it would be a good idea to do normal Sportster electrical checks:
A. Check voltage (a) key off, (b) key on, (c) engine at ~ 2,500 RPM ***
B. Tug test 4 battery cable ends, as well as inspect for looseness and corrosion.
For 2007-2009, especially (2007-2009 were the first generation of the EFI models. Wiring seems more complicated than necessary [8 fuses + 3 spare fuse positions] and the design of the fuse and relay locations did not consider ever washing the bike or parking it in the rain. However, if the fuse panel and relays are serviced, reliability seems normal):
C. Remove chassis/harness ground (top of trans), clean external and internal threads, apply copper based (conductive) anti-seize and reinstall. Or at least measure resistance from top of chassis ground wire lug to battery negative post. Should be 0.1 ohm or less...sames as for battery negative cable from top of trans to battery negative post.
D. Pull 30 amp maxi fuse, remove all 15 amp fuses, clean front and back of fuse block. Reinsert fuses, reinsert maxi fuse.
E. Replace system relay if more than ~ 2 years old, less if parked or ridden in rain.
***Voltages
1. KEY OFF battery voltage, at the battery: Normal is 12.8, acceptable is 12.6 (standard lead acid battery, not AGM) to 12.8 for no load. If just taken off a charger, voltage may be 13 point something. The battery needs to sit for a while before a reading is useful. In the case of a bad cell, the other cells overcharge and give an almost normal reading, until load is applied.
• If lower, then battery is discharged and needs charging or
• Battery has a bad cell
2. KEY ON battery voltage (headlight on): Normal is not under about 12.5 initially, but will decline the longer that the headlight is on, without the motor running. Under no load, 12.5 volts indicates 50% discharge, but under load, it is just voltage drop.
• Battery has a bad cell or
• Battery cable(s) have high resistance
3. KEY ON battery voltage while cranking: Normal is not under 10.5 volts
• Battery cable(s) have high resistance or
• Starter is drawing too much current
4. If the bike is running, battery voltage at about 2,500 RPMs should be 13.8 to 14.8
• If not, then check stator resistance and regulator ground
• If the stator is not shorted to ground and resistance is within spec, the regulator or regulator ground is suspect
5. When there is a problem with “no power” check the 30 amp circuit breaker or maxi fuse between the battery and the key switch and all the 15 amp fuses after the key switch (or circuit breakers on many Ironheads). If circuit breakers / fuses are OK, then measure voltage coming into the key switch and continue downstream until the voltage stops.
Old 18th July 2016
oilly1's Avatar
oilly1 oilly1 is offline
Sportster/Buell Model: XL1200Roadster #1
Sportster/Buell Model #2: XL1200R #2
Sportster/Buell Year #2: 2008
Other Motorcycle Model: 1984 FLHT, unforgotten
oilly1 has disabled reputation
Thanks, doc: as usual, a packet of very good instructions from you. You da man!
Old 18th July 2016
Ultrarunner Ultrarunner is offline
Sportster/Buell Model: XL883C
Other Motorcycle Model: FLHX
Other Motorcycle Year: 2007
Ultrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud ofUltrarunner has much to be proud of
Good information. My only real issue (if you can call it that) in ~10k miles on my '09 was electrical in nature, eventually traced to the relays/ fuse panel. Replacement of the relays and proper cleaning, and no problems since. Now a regular maintenance item. Thanks.
2009 XL883C
Old 18th July 2016
schwede's Avatar
schwede schwede is offline
Sportster/Buell Model: 1200 low
Sportster/Buell Year: 08
Other Motorcycle Model: fatboy
Other Motorcycle Year: 2010
schwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond reputeschwede has a reputation beyond repute
Doc. ...I take exception with the phrase "reliability seems normal "...as I can attest, if you treat the fuse box as a maintenance item, reliability will be normal. ..
if there is such a thing. ..can't give you any more rep...would if I could. ..
Excellent post. ..
Schwede
Biker Roots... some are born, some are grown, others will never know...
Old 18th July 2016
splineman's Avatar
splineman splineman is offline
Other Motorcycle Model: Honda GB400
Other Motorcycle Year: 1987
splineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond repute
Excellent advise and nicely written up, thanks!
Regarding the fuse block, I just cleaned mine up and it was corroded and pretty ugly on an '05 ridden regularly in the rain.
Old 19th July 2016
Thank you, Liz!
Old 19th July 2016
Excellent post. ..
Schwede
Thanks for the rep attempt! Do notice the exception clause in that statement:
"However, if the fuse panel and relays are serviced, reliability seems normal"!
Old 19th July 2016
Thank you.
More corrosion front or back?...and the 04-06 fuse blocks were a bit better positioned.
Old 19th July 2016
Thank you for the endorsement. I keep trying to spread the word to save a lot of unnecessary down time.
Old 19th July 2016
splineman's Avatar
On the front, where the fuses plug in. They are behind the left side panel behind the oil tank so not too bad positioned. I guess the warm oil may help them stay dry...don't know?
I am going to poke around a bit more to check my electrics out, seems vibration may play a part as well with rubbing.
