0 72 ih stroker advise needed
0 Ironhead engine problem?
Last Post: Congojack
0 Starting?
Last Post: Briank
Last Post: The Doctor71
Last Post: splineman
0 HAMMERPerf 90" In the Works
0 Starter gaskets 74 XLH1000
Last Post: Spent Brass
0 The Strociek Project
Last Post: Turbo Sporty 48
0 NOS cases
Last Post: BigMek
0 Video - Servicing the External Breather Catch Can
0 faulty throwout bering
4 Help with intermittent pinging noise at idle after warm-up
0 1983 motor in 1976 frame
Last Post: Racepres
0 Deer hunting at stairman's.
phantom, JaggedEdge (75), toe (61), john428 (61), testuser (57), rbuier (46), Insane (44), hdtech237 (41), overland47 (40)
Porkchop9 Porkchop9 is offline
Sportster/Buell Model: Custom 883
Porkchop9 is an unknown quantity at this point
Default Bad Vibration & Engine Stumbling 99 Custom 883
Vibration first noticed in handlebars in the last few months. Now the engine vibrates terribly and misses badly. The bike is not ridable. Bike starts using choke. Coil is within specifications.
I suspect the motor is running out of balance, maybe due to a faulty crank position sensor. Where is the sensor? It's not on the left side front under the oil filter as shown on some Sportsters.
Thanks in advance.
Porkchop
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Don't you just have the "nosecone" ignition module on your year bike. I don't think they had a crank position sensor on those years. I have read that the nosecone modules can go bad from engine heat. I think the crank sensor wasn't used until 2004.
John
Thanks, John, that's what I'm thinking. I don't understand what the nosecone module is.
Clymer manual says the ignition module includes the "cam sensor" located in the right side gearcase cover. but I think that's a separate sensor.
Where is the nosecone module?
Thanks much.
Steve Hughes,
Archer, FL
I think the entire ignition module on your bike is enclosed in the "nosecone" timing cover, it's the round protrusion on the right side camshaft cover. On my 1991, only the "cam sensor" (it reads off #2 cam) is within the nosecone and the rest of the ignition is just rear of the battery mounted on the frame. Your bike has the timing sensor (cam sensor) and ignition module components all in one unit under the nosecone. That's probably why the heat related failures are reported. In fact, HD does not even offer a replacement for that module as it was a loser. I'm not sure the preferred replacement as my bike has the separate ignition module, but I'm sure some forum members will be happy to provide some suggestions. I want to say a Dynatek nosecone replacement module is a popular choice, but don't take my word for it. I did put a Dynatek external module on my bike when I bumped it from 883cc to 1250cc per vendor's recommendations.
Failure of the nosecone modules is common, though not frequent.
Google "Ronnie's Harley Davidson microfiche." You can pull up a parts diagram of your bike and see the ignition module for your year, it's basically the Factory Parts Manual put online for selling on the internet.
Good luck, and welcome to XLF!!!! Lots of knowledgeable folks always happy to help you here.
John
Great help, John. Thank you very much.
Steve H.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
You might run a compression check. Make sure the motor is mechanically sound before you go chasing a potential tuning issue. Also, it'll give you the opportunity to inspect the spark plugs.
Click Here to Contact Me
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: FXR
Sportster/Buell Year #2: '89
Other Motorcycle Model: R50/5
Other Motorcycle Year: '73
Fivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond repute
From the http://sportsterpedia.com/lib/exe/de...o.jpg?id=start
Ignition info for the '99. READ DOWN to the correct year
http://sportsterpedia.com/doku.php/t...k:evo:engctl01
Also, when were the plugs & wires replaced?
Compression! Yes. Thank-you.
Great ignition info, too. Sportsterpedia, wow. I'll check the spark with a timing light & replace the plugs.
The bike has 13k miles. I've owned for eighteen years & never ran it hard. I replaced the carb recently and was doing trial runs. The terrible engine vibration caused me park it.
Thanks again,
Steve Hughes
Archer, FL
Did the "terrible engine vibration" start right after you replaced the carb?
When problems start after you've worked on the bike, the first thing you look
at is the last thing(s) you did.
Thanks, I agree. I rode the bike 2 or 3 times after the new carb, but just for a few miles. I was fine tuning the idle and cable adjustments when the vibration began.
Good suggestion, I'll look real close at the carb set-up. Thanks again.
