0 Ironhead engine problem?
Last Post: Congojack
0 Starting?
Last Post: Briank
0 72 ih stroker advise needed
Last Post: The Doctor71
Last Post: splineman
0 HAMMERPerf 90" In the Works
0 Starter gaskets 74 XLH1000
Last Post: Spent Brass
0 The Strociek Project
Last Post: Turbo Sporty 48
0 NOS cases
Last Post: BigMek
0 Video - Servicing the External Breather Catch Can
0 faulty throwout bering
4 Help with intermittent pinging noise at idle after warm-up
0 1983 motor in 1976 frame
Last Post: Racepres
0 Deer hunting at stairman's.
phantom, JaggedEdge (75), toe (61), john428 (61), testuser (57), rbuier (46), Insane (44), hdtech237 (41), overland47 (40)
Gravitas Gravitas is offline
Sportster/Buell Year: 1982
Gravitas is an unknown quantity at this point
The transmission vent should have a tube running straight up, then doing a 180` turn pointing down. Nothing ever drips from it.
OK. How likely is it that I will manage to get a tube on it without removing the Solenoid?
The nipple is under the starter, can't run it straight up.
The routing was changed for 1981-up models.
See this service bulletin.
http://www.sportsterpedia.com/lib/ex...in:tsb0813.pdf
The transmission vent hose should be routed under the starter, over all the oil lines and the rear brake line, then down between the pivot bolt and swing arm.
It looks like they were trying to keep the curves in the hose from being too sharp.
You might try hemostats to get the hose on the nipple?
I believe that this is a jargon issue. Thanks for the post I also saw this one elsewhere.
I am referring to the transmission vent nipple which is directly under the solenoid/starter, I believe that you are referring to the cam/gearcase vent which feeds back to the oil tank.
Please ignore my other post, my bad!
No problem.
