0 Things to Ponder game
Last Post: Eddieblz
0 Help with rear pipe ID please
0 answer with a question game
Last Post: Eddieblz
0 XB12R rear brake switch thread size?
Last Post: Lone Rider
Last Post: T. Clark
Last Post: Bama Lee XLC
6 Calling all musicians
Last Post: Eddieblz
1 2019 Iron 883 Drag Bars
0 Rode today, 10 days post op.
Last Post: farmall
0 Shoulder rotator cuff problems
Last Post: farmall
0 CV conversion help
Last Post: farmall
0 81 XLH Starter Wiring
Last Post: owlsplace
0 Wisdom of an older man!
Last Post: Eddieblz
0 Loose solenoid bolt
Last Post: priell3
0 got pulled over the other day....
Last Post: Campsurf
Last Post: spamer80
0 Starter/solenoid issue
Last Post: Dshank14
Last Post: Yakcm2
Last Post: Bored now
Old 5 Days Ago
FrankZ's Avatar
FrankZ FrankZ is offline
Other Motorcycle Model: ATK 605
Other Motorcycle Year: 1998
FrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to beholdFrankZ is a splendid one to behold
Default Can you tell if my engine isolator bushing is bad by looking at these pictures
Can you tell if my engine isolator bushing is bad by looking at these pictures.
It is a 2006 XL1200C with 24K miles on it. I mean I can see it drooping a
little but is that enough to warrant replacement?
https://imgur.com/Z0C9tUU
and this one
https://imgur.com/YlUPTZp
Old 5 Days Ago
jzink0883's Avatar
Sportster/Buell Year #2: 1998
FrankZ,
I remember reading a rule-of-thumb that said: If you disconnect the upper tie link and the engine drops, it’s time to replace the isolator.
Old 5 Days Ago
FrankZ's Avatar
Thanks jzink. I will go disconnect some tie links and see what happens.
Old 5 Days Ago
oldboy's Avatar
oldboy oldboy is online now
Other Motorcycle Year: 1974
When I did mine the engine dropped about 10 mm when I removed the front links. With the new ones installed the linls lined right up. Also, with the old isolators, there was excessive movement of the engine to frame at idle.
Old 5 Days Ago
rejeanprimeau's Avatar
Simple, YES
Old 5 Days Ago
1Scooter 1Scooter is offline
1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about
YES they are BAD.
