0 Things to Ponder game
Last Post: Eddieblz
0 Help with rear pipe ID please
0 answer with a question game
Last Post: Eddieblz
0 XB12R rear brake switch thread size?
Last Post: Lone Rider
Last Post: T. Clark
Last Post: Bama Lee XLC
6 Calling all musicians
Last Post: Eddieblz
1 2019 Iron 883 Drag Bars
0 Rode today, 10 days post op.
Last Post: farmall
0 Shoulder rotator cuff problems
Last Post: farmall
0 CV conversion help
Last Post: farmall
0 81 XLH Starter Wiring
Last Post: owlsplace
0 Wisdom of an older man!
Last Post: Eddieblz
0 Loose solenoid bolt
Last Post: priell3
0 got pulled over the other day....
Last Post: Campsurf
Last Post: spamer80
0 Starter/solenoid issue
Last Post: Dshank14
Last Post: Yakcm2
Last Post: Bored now
Old 4 Days Ago
ericfx1984's Avatar
ericfx1984 ericfx1984 is offline
Sportster/Buell Model: 1000 Ironhead
ericfx1984 is an unknown quantity at this point
Default I have been busy... 1975 sporty, stretched w/evo
So I found a killer deal on an Evo Sporty 883 with a Crane Cams hi-4 ignition for dirt cheap
I already had the Ironhead out due to a crank pin failure a while back (on a side note the Ironhead is almost back together)
While I had the engine out I stretched the seat ‘subframe’ 3” as well as the swing arm
https://www.amazon.com/photos/shared...NCqFmrbMXECa2g
https://www.amazon.com/photos/shared...eCtrXI7z3ah-TN
https://www.amazon.com/photos/shared...6NLHDGo4-tODHQ
https://www.amazon.com/photos/shared...naOeXA3kJv74Eh
https://www.amazon.com/photos/shared...gY9Z2tLgt2_LMx
https://www.amazon.com/photos/shared...RMzfdOhjeJ3S3o
Over the weekend I tried to install the evo in my Ironhead frame. It wouldn’t fit between to lower frame rails... it was hitting on the inside of the left lower frame rail....
Cut it, reinforced it... braced it and it dropped in... but didn’t clear the front of the rear cyclinder.
Looked again, the kickstand and the foot peg mounts are in the way, cut that off move it forward... not sure what I’ll do about the foot pegs or foot controls
Took the cover off and it cleared the backbone...
but now it didint clear the rear motor mount... made some blocks. Now it clears
Then the front mounts where too far forward, just a little grinding... they fit...
This weekend I will pull it and clearance and reinforce the backbone
It should be running in a couple weeks...
Over the winter I plan to convert to a 1200
1975 Harley Davidson Ironhead Sportster 1000
Old 4 Days Ago
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Yep. You look busy to me. Good Luck with everything.
Traveled to
Old 3 Days Ago
Glamazon Glamazon is offline
Senior Bike Builder
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
Looks nice, there was a few evos in pre 79 frames shown here. Always liked the pre 79 frame bikes & can remember the outrage 40 years ago that the 79s "weren't a real Sportster"!
