Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Hammer Performance
0 Things to Ponder game
Last Post: Eddieblz
0 Help with rear pipe ID please
0 answer with a question game
Last Post: Eddieblz
0 XB12R rear brake switch thread size?
Last Post: Lone Rider
Last Post: T. Clark
Last Post: Bama Lee XLC
6 Calling all musicians
Last Post: Eddieblz
1 2019 Iron 883 Drag Bars
0 Rode today, 10 days post op.
Last Post: farmall
0 Shoulder rotator cuff problems
Last Post: farmall
0 CV conversion help
Last Post: farmall
0 81 XLH Starter Wiring
Last Post: owlsplace
0 Wisdom of an older man!
Last Post: Eddieblz
0 Loose solenoid bolt
Last Post: priell3
0 got pulled over the other day....
Last Post: Campsurf
Last Post: spamer80
0 Starter/solenoid issue
Last Post: Dshank14
Last Post: Yakcm2
Last Post: Bored now
lucifer_mr2 lucifer_mr2 is offline
Sportster/Buell Year: 2012
lucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant future
Default Head gasket leak.
I did a 1275 conversion with SE heads, 560 cams. Recently noticed a small head gasket leak that happens when the engine is cold.
Sounds like a bit of a knock, but felt it from the rear head. After the bike is warm the leak goes away.
How, much would it cost to get a new set of Cometic gaskets, C10094-3625 delivered to Australia?
Air-Cooled Forever
You could always opt to loosen the head bolts and go thru the torque sequence again, then index the head bolts. Or just tighten them down another 1/8th turn.
{Just thinking out loud}
Lifters sticking?
Check the rocker box for witness marks.
High lift cams can cause the springs to hit the box.
More here on clearancing the boxes in the Sportsterpedia:
http://sportsterpedia.com/doku.php/t...ref:engmech02f
Old 1 Day Ago
Well, stripped it down. Like it felt, there was a head gasket leak. The gaskets still looked good, head bolts seemed a little loose. Refit it all and retorqued to spec (7,14,22,34 and 42). Bike is running great now.
Will probably get a set of gaskets later to keep on the shelf but in no rush at the moment.
Also had a small drag race with some other local riders. MT09 was behind me the whole way. Bike just launches so hard and makes great power. Got 23,000km on the kit so far and am very happy with it.
Old 1 Day Ago
Air-Cooled Forever
Glad for you. Most of those naked/sport bikes have never seen a Sportster's torque curve. If we had about 2 more gears, we could outrun them up to 130mph!
Old 1 Day Ago
My torque curve looks a little more peaky than factory. Doesn't seem to love it much below 3000rpm. Still makes OK power, but nothing compared to what it does after that. And shifting up into second at ~80km/h will lift the front wheel a bit.
