Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 1977 Bright Blue
0 HAMMERPerf 90" In the Works
Last Post: robistro
Last Post: T^2
Last Post: jordan1200
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
0 Joe Minton article on HSR 42 tuning
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 CARB: 2024 motorcycle emission requirements; Maybe as early as 2021?
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
0 Not charging issue!
Last Post: Jowniofownio
0 Future of the sporty?
Last Post: hexnut
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Last Post: 883openpipes
0 Intro from New England
Last Post: peteskipsleg
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
0 Diagnostic help
Last Post: BradX13
Last Post: RKN
SoCal 1200N (57), riverar7 (53), rx3732 (44), gnrxl2002 (40)
Old 13th June 2017
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
Default Primary chain adjustment without the window
Here's the deal:
My 2000 S3T had a few issues last year. I ended up replacing the main shaft bearing (and made my own tool to do it), and that has stopped the oil from blowing out the vent hose and dripping on the tire.
My issue is that when I went to open up the side cover, I noticed that one of the screws holding the primary chain inspection cover had a stripped head. I tried several tricks to remove it before breaking out the Speed-outs (didn't work) and another screw extractor (not a cheap one either).
I am not new to this procedure and I was really surprised when the screw extractor broke off in the screw head... So I break out the mini drill press, rig up a strap clamp and 'uge! c clamp to hold it in position as I attempt to drill out the screw extractor. The bit drifted and started a hole next to the extractor, so I stopped. I cannot get that damn screw out and it should not be in that tight. I even heated it up a little bit, but not enough to melt the o-ring. So I figure I do not have the right tools or skill to get that screw out, but I would like to make a temporary primary chain adjustment, so I can get this bike to the shop so they can try to remove that screw.
Is there a procedure I can follow, that will allow me to tighten the primary chain so I can ride the bike a bit without having access to the inspection cover??
Is there any other way I can try to remove the screw without damaging the cover?
Thanks!
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
Old 13th June 2017
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
I read on here a long time ago about adjusting the primary chain (on Sportsters) by sound. Ever since, that's the way I've done it. I usually start by using the inspection cover but always fine tune it by listening. You don't want the chain to whine (too tight) but you don't want it slapping around (too loose). Adjust the chain with the bike running and you'll hear it. Tighten until it whine's a little, then back it off just a bit.
Is there a reason this wouldn't work the same way on a Buell?
See some discussion about it in this sticky thread.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 13th June 2017
Just want to add a note, this " ear" adjustment works best if the power plant is warmed up. Been doing it for over a dozen years without issue.
Old 13th June 2017
r4fthrs's Avatar
r4fthrs r4fthrs is offline
Sportster/Buell Year: 07
r4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond repute
Airbozo - have the same problem my inspection cover screw head has been stripped for 4 years. I do the method Screw Loose Dan suggests and I think it is the better method. When I did it the Moco way I always ended up doing it two to three times before it was right (would either whine when it was hot or rattle when cold).
Adjust it when hot, slowly tighten the adjusted until it slightly whines and back off until the whine stops and an additional 1/4 turn and it is perfect every time. The company advises against it because if you accidentally hit the shifter the bike will take off, but if you are concerned about safety, put it on a center jack and lift the back wheel.
Armed you are a citizen, unarmed a subject.
Fear the government who fears your guns.
An armed society is a polite society.
Old 13th June 2017
Airbozo's Avatar
Excellent information on the adjustment. I thought I read something similar, but could not find it during a search.
I ran out of time to try this until I get back from vacation, but I will attempt it then. Thanks a lot for the info!
Old 13th June 2017
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Hot damn. I KNEW there had to be a better way. Sometimes things pop up on this site randomly that really help.
Thanks.
You can't keep a good man down......... unless you tie weights to his ankles.
