0 1977 Bright Blue
Last Post: Larry May
Last Post: robistro
Last Post: T^2
Last Post: jordan1200
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
0 Joe Minton article on HSR 42 tuning
Last Post: The Crusher
0 HAMMERPerf 90" In the Works
0 2001 883 'customizing' log
Last Post: Jheitt
0 CARB: 2024 motorcycle emission requirements; Maybe as early as 2021?
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
0 Not charging issue!
Last Post: Jowniofownio
0 Future of the sporty?
Last Post: hexnut
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Last Post: 883openpipes
0 Intro from New England
Last Post: peteskipsleg
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
0 Diagnostic help
Last Post: BradX13
Last Post: RKN
SoCal 1200N (57), riverar7 (53), rx3732 (44), gnrxl2002 (40)
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Model: XLH Sportster
Sportster/Buell Year: 1984
Yochstein will become famous soon enoughYochstein will become famous soon enoughYochstein will become famous soon enoughYochstein will become famous soon enoughYochstein will become famous soon enoughYochstein will become famous soon enough
Default Exhaust Clamp Fitting
I've been having an exhaust leak at the head where the exhaust pipes connects. Do I cut extra slits into the inlet of the exhaust pipe or create some sort of shim for the head with an aluminum can? I have torqued the exhaust clamp down to the point where I don't want to strip the bolt or damage the clamp. What have you guys done?
c1skout's Avatar
c1skout c1skout is offline
Sportster/Buell Model: sportster 1200c
Other Motorcycle Model: Royal Enfield / BMW
c1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud ofc1skout has much to be proud of
Not much info to go on from your question, I'll say remove pipe, remove flange from pipe, make sure flange is flat. Remove all traces of the old gasket from inside the head, then install new gasket being sure to install it straight with no deformation. install pipe and torque to factory spec........no tighter! That should cure any leaks. If not report back.
Yochstein's Avatar
Sorry for not being very clear. I snapped a shot of what I'm talking about. You can see at the base of my pipes where the exhaust leak is happening. It's basically not making a complete seal around the exhaust extension from the head.
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud ofDave L has much to be proud of
My 85 has a thicker material clamp. Not as wide but much thicker in material. That style should work on yours as well. I can see why yours would leak.
J&P Part: 4400250
Dave L's Avatar
Yochstein's Avatar
I used new exhaust clamps that came from the local HD dealer. Do you have an idea of which clamp I should be using?
rokytnji's Avatar
rokytnji rokytnji is online now
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Cushman Truckster
Other Motorcycle Year: 1990
I am not using dealer clamps on my 1980. But if you can find these at a industrial supply house. They work pretty good for me.
http://xlforum.net/forums/showpost.p...8&postcount=45
Oh crap! Just found out my scooter is only worth 1500 bucks. Oh well.
Traveled to
