Last Post: Lone Rider
Last Post: koolbreeze
0 Who's still riding???
Last Post: ezmerf
0 My cold weather attire.
Last Post: ed_in_az
Last Post: dhalker
Last Post: Jaykel
0 timing sympstoms
0 Guzzi V7
Last Post: Bone
0 Wanted - XL HANDLEBARS for 69CH
Last Post: Garym1
0 Wheel Bearing Question
0 Rivets for Front Fender Braces - '71 xlch
3 How long have you had your Iron Head?
Last Post: bremoit
0 Dale's Killer 40mm CV Carb
Last Post: Moon Wolf
0 Let's See Them R's!!
Last Post: PetesPonies
0 Hello Everybody
8 Tc88a
Last Post: Mjolnir
0 Forum member mug shots
Last Post: RAIDER0372
Last Post: Bama Lee XLC
0 Helmet poll
0 Fork oil
0 XR1200 Torquehammer exhaust failure.. again.
Old 19th August 2018
Sportster/Buell Model: XLH883
hammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to beholdhammer6315 is a splendid one to behold
Originally Posted by decman View Post
You should try running high test gas. 91 octane
Using regular will cause run on.
Also most high test is Ethenol free, well around me it is.
I considered that. I do like high test being ethanol free. Maybe give it a try. It is sold around here, at some gas/conveince stations.
60Gunner's Avatar
60Gunner 60Gunner is offline
There is a difference between states on whether premium gas specifically has ethanol in it or not. Or, more correctly, whether it's required to have it in it. ... This is because they have to use the ethanol to raise the octane level of their gasoline blend in order to satisfy the higher octane requirements of premium.
Around me, only 2 stations have pure gas and one of them has 87 octane and 91 octane both ethanol free. I run the 91 pure gas myself.
It's up to the station owner what he's gonna carry but premium does not mean ethanol free.
But I live in corn country so. There's an ethanol plant 15 miles away that I deliver anhydrous ammonia to. We also deliver fuel and the different blends from station to station and bulk plant to bulk plant is mind boggling.
05 1200C w/custom timing map 'VooDoo'
Dragtron II/K&N filter/Cycle Shack pipes/HP+baffles
45/175/N65C shimmed .040/ICM 1-3/4 turns
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Well like some people said it might be timing related. Well yes it is and
changing to premium is the fasted way to tell, without tools.
Ethenol or not, run premium.
Diogenes415's Avatar
Originally Posted by hammer6315 View Post
How do you riders deal with this situation? I'm talking 2006 XL883. 9:1 compression ratio. I burn regular fuel. No pinging while riding.
My completely stock 2006 883C would sometimes diesel on shutdown, take forever to warm up and run without a hiccup and would occasionally stumble while droning on the freeway regardless of season, summer or winter. Some folks on this forum who experienced the same problem were able to get their bikes to run correctly by shimming the needle. At the suggestion of someone who's input I value I opted for the N65 needle sold by J&P Cycles and to my surprise it resolved my bike's issues.
Nope, it's a Sportster.
Folkie Folkie is offline
The timing's not likely to be 'out' on a stock rubbermount, since it isn't adjustable*.
*: At least not without programming the ICM/ECM.
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
run-on, dieseling or whatever name you want to call it occurs from advanced timing, too lean of a mixture, too hot a cylinder , retarded timing , too high a idle rpm.
Default too cylinder
And that's when it is most likely to happen to me; when the engine is at above average temp.
Old 20th August 2018
60Gunner's Avatar
First thing I did when I bought this bike was get rid of the dynojet stuff and put the N65C in.
It does have a lean spot just off idle tho. That's why I shimmed it. It's a longer needle. Takes longer to hit the taper otherwise.
frankman's Avatar
frankman frankman is offline
Sportster/Buell Model: XL1200N Nightster
Sportster/Buell Model #2: XL1200C Custom
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Kawasaki ZX14R
frankman is an unknown quantity at this point
Default run on
The bike dieseling after shut off is from a carbon deposit on top of your pistons, it burns like ember's and ignites unspent fuel after engine shut off, you need to run an additive such as seafoam in fuel, not a fuel line cleaner, but a carbon burning additive and run the shit out of it for a while
