Last Post: Lone Rider
Last Post: koolbreeze
0 Who's still riding???
Last Post: ezmerf
0 My cold weather attire.
Last Post: ed_in_az
Last Post: dhalker
Last Post: Jaykel
0 timing sympstoms
0 Guzzi V7
Last Post: Bone
0 Wanted - XL HANDLEBARS for 69CH
Last Post: Garym1
0 Wheel Bearing Question
0 Rivets for Front Fender Braces - '71 xlch
3 How long have you had your Iron Head?
Last Post: bremoit
0 Dale's Killer 40mm CV Carb
Last Post: Moon Wolf
0 Let's See Them R's!!
Last Post: PetesPonies
0 Hello Everybody
8 Tc88a
Last Post: Mjolnir
0 Forum member mug shots
Last Post: RAIDER0372
Last Post: Bama Lee XLC
0 Helmet poll
0 Fork oil
0 XR1200 Torquehammer exhaust failure.. again.
Old 19th August 2018
Mrhorn12 Mrhorn12 is offline
Sportster/Buell Model: 1978 xlh1000
Mrhorn12 is an unknown quantity at this point
Default 78 new Ultima ignition problems
Installed the new Ultima. Got 14 miles and she backfired, and stalled. Now it wont start. Green and red lights quickly flash and a clicking happens when trying to start. Retimed it, re wired, etc. Any ideas?
Old 20th August 2018
would have to check my library but does the leds quit after key cycle? off the top, the ultima will go into over current protection so check your paper work. if it is, check all wiring and make sure you have the correct coil. if all is good, could be the module.
Something else is happening here. Horn and lights went dead. Have had it on a trickle charger all night. Starts right up now. But... Battery is not getting to full charge and something is draining the battery. Im guessing she stalled the other day due to losing juice on the ride. Bad generator? How to know?
