0 79 Engine Rebuild
Last Post: Peteroo
Last Post: bplinson
0 hey y'all
Last Post: conv90
0 Issue that has me stumped
0 wtb cam cover and primary cover for 2003 sportster
Last Post: painterdude923
Last Post: gravydog
0 Any K model guys interested in cam regrinding?
Last Post: sevenyears of famine
0 Where to buy auto advance weights
Last Post: AkIronheadparty
0 Satisfied Hammer Performance Customers
Last Post: rider61
Last Post: kaveebee
0 Which cam?/ 551 or 570/Why?
Last Post: Turbo Sporty 48
0 C.O.B.B run west
0 Electronic jet kit
6 SPORTY BOBBER PICTURES
0 Who can make a spare key?
Last Post: chris16371
Last Post: Four Speed
Last Post: lucifer_mr2
0 Clutch Spring plate poll
Last Post: r4fthrs
0 How old are you?
Last Post: RandyMac
0 2 Up Seat Recommendations
Last Post: ReddTigger
Old 3 Days Ago
Adam13's Avatar
Adam13 Adam13 is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 1974
Adam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the roughAdam13 is a jewel in the rough
Default Generator/regulator circuit breaker
Just had to replace my regulator in my 74. Pretty sure I ran it without polarizing. I got it with a cycle electric 65A and it had a different brand bolt on regulator. I mistook it for a gen/reg combo from cycle electric and read that you didn’t have to polarize every time. Live and learn...anyway bought a cycle electric C-540 and installing now. The other thing I am correcting is I’m going to run it through a breaker. Previously it was straight to the battery. Which brings me to my quick question. It feels like I should run the wire from the gen/reg to the BAT side of the breaker then out of the breaker to the battery, since that’s how the electricity flows. Is this correct?
Old 3 Days Ago
The stock location for connecting the charging system is the output side of the Main Circuit Breaker (or fuse) - NOT THE BATTERY SIDE...
The main circuit breaker or fuse (as HD wires it) will keep the battery safe from a short in the bike wiring or a short in the charging system - Without that Main Fuse, as wired, a dead short in the bike wiring or a dead short in the charging system will cause the battery to go to maximum current & possibly explode - Bad news for your butt ! ! !
The Main Fuse does not protect the charging system from a short in the bike wiring...
This is the reason you SHOULD ALWAYS have additional circuit-specific circuit breakers (or fuses) to protect the bike wiring in case of a short which will also protect the charging system from a short...
2 Relax
Old 3 Days Ago
Adam13's Avatar
Thank you my friend. I’m glad I asked. In this instance the bike is pretty well chopped and when I got it, it had no circuit protection at all so I bought a set of 3 breakers, sized same as stock for 74. Basically I’ve got one for lights, one for ignition, and the charging system is now going through the third all by itself. I put a starter on it (XLCH) and ran it through a fuse just for sake of simplicity.
