0 79 Engine Rebuild
Last Post: Peteroo
Last Post: bplinson
0 hey y'all
Last Post: conv90
0 Issue that has me stumped
0 wtb cam cover and primary cover for 2003 sportster
Last Post: painterdude923
Last Post: gravydog
0 Any K model guys interested in cam regrinding?
Last Post: sevenyears of famine
0 Where to buy auto advance weights
Last Post: AkIronheadparty
0 Satisfied Hammer Performance Customers
Last Post: rider61
Last Post: kaveebee
0 Which cam?/ 551 or 570/Why?
Last Post: Turbo Sporty 48
0 C.O.B.B run west
0 Electronic jet kit
6 SPORTY BOBBER PICTURES
0 Who can make a spare key?
Last Post: chris16371
Last Post: Four Speed
Last Post: lucifer_mr2
0 Clutch Spring plate poll
Last Post: r4fthrs
0 How old are you?
Last Post: RandyMac
0 2 Up Seat Recommendations
Last Post: ReddTigger
0 Bannana Caliper 73 XLCH- no brakes?!?
Last Post: JacksBrother
Old 3 Days Ago
rocketmangb's Avatar
Brackets
Bracket on the right is for a Sportster
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 18 Hours Ago
intoanother intoanother is offline
Sportster/Buell Model: 883 (with 1200 Kit)
intoanother is an unknown quantity at this point
Thanks again for helping with the questions.
swapped the carb over and love it. Had a couple of heart sinking paranoia moments when test riding thinking it was cutting out. Then realized I'd just eased off the throttle it's that responsive
One more on the choke cable and compatibility,
I lost the elbow from the cv carb so ended up using a barrel adjust from a bicycle brake to make it work and give the "correct" tension as a temporary set up
If I order Mikuni Choke Cable - Manufacturer Part Number: 990-662-002.
Do I have to swap the parts between the two cables as described here http://www.mikuni.com/fs-choke_cable.html
or can I use the mikuni one as a complete replacement?
Old 12 Hours Ago
I think you have to use those parts over
