Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > NON-ENGLISH FORUMS > Suomeksi
Suomeksi Suomenkieliset sivut
0 Too HOT to ride?
Last Post: Bigshankhank
Last Post: TUCCI
2 My 1275 Hammer Conversion..
0 su carb question
Last Post: Billy1200
Last Post: Traxx
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 Why cafe a sportster?
Last Post: TUCCI
0 New to the Chopper Lyfe
0 Anyone put a mechanical speedo drive on the rear wheel?
Last Post: xl883lo
0 Wtb--1967--1972 xlh
Last Post: Doc308
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
Old 2nd September 2012
shotgun46's Avatar
Looking good so far !
Sportsters Rule ! :banana
Old 6th September 2012
samppa's Avatar
samppa samppa is offline
Sportster/Buell Model: XLH883H'97
samppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of light
Got the new seat today, MoCo's sport II:
Kunnon morsettaja piikkaa molemmin käsin.
Old 22nd September 2012
jsr85's Avatar
jsr85 jsr85 is offline
Sportster/Buell Model: 883-1200
jsr85 is an unknown quantity at this point
Tulipa kirjauduttua tännekkin ja tutun näköisiä mopoja finnbikerssiltä tulee vastaan
Mitä mieltä olit noista 12" takapumpuista? Olis tarkotus oman mopetin persausta laskea mut ei oikeen tiedä mitä laittais alle, toiset meinaa et sama vaik jäykkäperäksi laittais jos vaihtaa nuo lyhyet...
Pitäs varmaan kohta rohjeta omakin rojekti avata....
Old 28th September 2012
samppa's Avatar
Joo, tulee pyörittyä useammalla foorumilla, vaikka suomalaisiltakin foorumeilta, erityisesti Finnbikersilta, saa hyvin apuja ja tietoa, niin täällä on enemmän jengiä ja löytyy kokemuksia erikoisemmistakin kikkareista.
Mulla noi 12" on oikeasti dynan pamput, joten niissä vaimennus on mitoitettu raskaammalle pyörälle... Eli oli melkosen kovat ajossa. Erityisesti velton stanuetupään kanssa tunnelma oli aika veikeä. Jos on tarkoitus slämmätä perä, niin itse tekisin PS:n 11,5 iskareilla, mulla oli sellaiset aikoinaan ekassa sportsterissa kun halusin laskea perän mahdollisimman alas. Muistaakseni toimi ihan ok jopa 2-päällä ja kuormalla.
Kannattaa oikeasti laittaa myös eteen kunnon jouset samalla kun pistää takapään kuntoon.
Old 5th October 2012
samppa's Avatar
Default Da Upgrades...
Supertrapp and S&S air cleaner. I think I love DK's outlet and "beat-it-by-a-buck" policy... Both parts would have cost me mucho dinero more if purchased locally, even after shipping + customs & taxes.
Old 7th October 2012
samppa's Avatar
OH sh*t, didn't realize the light was that bad...
Old 28th December 2012
jsr85's Avatar
Minkälainen/kuinka iso ääni tuolla putki/päätylevy combolla on? tuli itekki hommattua samanlainen putki ku halvalla sain, mut siin on vain 6kpl noita levyjä ja avoin pääty, jännää et joutuuko heti ostamaan lisää levyjä ja umpipäädyn...
pitäs aloittaa omakin projekti ku sai viimeisen tilauksen lähtemään, jospa se kusti vuodenvaihteen jälkeen tois paketin.
ps. onko nuo mid controllit myynnissä? olin näkevinäni jossakin jotaki pilletti käikäleitä.
Old 31st December 2012
samppa's Avatar
Mulla on siis 12 levyä ja umpipääty, sen päällä muutama levy ja avolaippa... Avolaippa siis täysin ulkonäkösyistä. 12 levyllä ja umpipäädyllä ääni on ehkä vähän liiankin hiljainen, pitää keväällä säädellä levyjen määrä kohdilleen.
Mid controllit eivät ole vielä myynnissä, pitää ensin kokeilla miten rearsetit kohtelee lonkkia. Paikallaan tuntuis olevan ok, mutta oikeat ongelmathan näkyy ja tuntuu vasta ajossa.
jsr85's Avatar
Ok, huuteleppa jos tulee myyntiin.
Old 12th February 2013
hhugger's Avatar
hhugger hhugger is offline
Sportster/Buell Model: 05 SPORTSTER XLH 883 Carb
Other Motorcycle Model: 16 BMW K1600GTL Exclusive
hhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond reputehhugger has a reputation beyond repute
Thumbs up European sporty meets 2013.
Good News.!
SPORTY Euroopan KOKOUS - International.
linkki:
http://xlforum.net/forums/s...1570998&page=8
Good News.!!!!!
European SPORTY MEETING - Internacional.
Link:
Suomi Oberbronn
Huom:
Käännös On Line
