Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > CV Performance
0 Krome Werks HP Plus slipons - Replacements ?
2 My 1275 Hammer Conversion..
Last Post: seajay
0 Figure Machine external breather
Last Post: SLW210
Last Post: TUCCI
0 Who Runs Turn Signals?
0 Bigger rear Pulley
Last Post: SLW210
0 TC88a DIY Power adapter ?
0 Magneto base for 70 XLCH
Last Post: panama86
0 Front brake calliper strange noise...
Last Post: TUCCI
Last Post: Clevspeed
0 How tricky is it to replace dipstick trim from oil tank?
Last Post: TUCCI
0 Too HOT to ride?
Last Post: SLW210
Last Post: orvitarius
0 Hi from Barcelona!
1 Pics of pets and what type of animals you have
Last Post: stikflote
0 high milage sportsters
0 Shifter shaft seal.
Last Post: vagrant318
0 A tale of two wheels
Last Post: Matt Black
0 su carb question
Last Post: Bryan83taco
0 Trans corner fix
0 Frankenbrakes
Last Post: Segway
0 Swingarm bearings - boy I'm glad I looked at them
Last Post: 1Scooter
0 wtb - swingarm pivot locknut
Last Post: jsandidge
0 Cough and sputter resolved
stroker ace (80), beunme (60)
Old 7th June 2015
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud of
Default Torque Cones for '90 XLH883
I was thinking of pulling the trigger (since they are on sale) and buying some of these but have a question first.
I'm running a stock exhaust EXCEPT the baffles are removed from the SE mufflers, the crossover is still functional.
I made my own lollypops and the bike pulls better.
I did the basic kit for the carb before I decided to pull the baffles/lollypops.
So my question is, can I (should I) run these cones with my exhaust and remove the lollypops?
Or should I just leave it.
I'm getting a good constant 65mpg with my current setup.
http://www.cv-performance.com/exhaus...ceted_search=0
Thanks,
Jim
Old 7th June 2015
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
What I heard is just as good as the torque cones, and doesnt cost anything, is before you start your bike, knock 3 times on the tank and say "harley harley go fast"
A good 2 into 1 would do the trick. But that an investment, and ya gotta like the 2 into 1 look.
I think your money would be better spent elsewhere. Maybe other guys have had a good experience using them.
Old 7th June 2015
shanneba shanneba is offline
Anti-Reversionary Cones Dyno Test
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 7th June 2015
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Why do you think you need them?
Sent with :-P
Old 7th June 2015
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
Sent with :-P
Because like religion you have Believers who do not need evidence?
It's Hammer time
Old 7th June 2015
Rollbar's Avatar
Sent with :-P
I was thinking they would work better than the lollypops since they are manufactured for that reason and not me just making a lollypop and no testing done except the seat of my pants. If the cones would be better/in tune better then I guess they would be better.
If the cones work better, then I'm all for it, if not, I'll run what I have.
