Last Post: spitfirechopper
0 2021 Harley-Davidson Bronx
0 '86 1100 basket build
Last Post: Onlybckroads
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Stacking the Alto Carbonite clutch !
0 fork reflectors
0 su carb question
Last Post: trappnman
0 How much can I get for my sporty?
Last Post: IronheadPhil
Last Post: Kbetts
0 Quick brake question...
Last Post: tussuck
0 Plug for Siren
Last Post: brixtonanima
0 Where we are! Put yourself on the Map.
0 high milage sportsters
Last Post: TUCCI
2 My 1275 Hammer Conversion..
Last Post: Proteus
Last Post: tennmoto
0 Bigger rear Pulley
Last Post: oldboy
0 Modify my dyna 2ki ignition
Last Post: vagrant318
0 Trans corner fix
Last Post: Proteus
nailhead (78), Rooster (63), chidovampiro (61), daniel (58), evereyken (57), RogueXR9OO (57)
Old 12th April 2019
shawn2002 shawn2002 is offline
Sportster/Buell Model: 2010 XL1200N
shawn2002 is an unknown quantity at this point
Default Fender chop help
I've done a pretty thorough search and can't seem to find an answer to my issue. I cut my fender tonight and cant figure out how I'm supposed to rotate it and remount. I obviously need to drill new holes on the sides to mount it to the frame but doing that leaves my seat mounting holes cock-eyed. I'm I SOL with my seat? It seems like I've seen lots of guys chop fenders and still use a "traditional" solo seat.
This is what I'm wanting to end up with. As you can see, rotating it this way means my seat mount holes dont really line up. Maybe with a spacer of some sort but that will look pretty silly.
This is what I have now.
Old 29th April 2019
Holytown Holytown is offline
Sportster/Buell Model: XL1200
Holytown is an unknown quantity at this point
Are you concerned with the gap between the tire and the fender? That'll be tough to get rid of with the stock fender. Its made to be deeper there so the rear tire can float up and down with the swingarm. its not a true constant radius fender like an aftermarket would be.
Old 29th April 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
This thread is over 2 weeks old, have you figured something out yet? I'd say, you need to weld some flat metal into those slots and then mark it and drill it where you want the fender to set.
