0 compensator
0 words fail me
0 runs-on after kill button pressed
0 Works Performance fork springs alternative
Last Post: Bulpitt
Last Post: Racepres
0 XR1200: Jerky throttle response, mostly around 3000 RPM
Last Post: Tucson_Tim
0 Non-stop questions,... lever mounts?
0 You all come back now you hear!
Last Post: Scuba10jdl
13 %~%#~wobble ^!^^#!#^
Last Post: Mr Dream Merchant
Last Post: Bwf347
0 Add resistor to turn signal circuit?
Last Post: VaFish
0 To seal or not to seal!
0 ‘19 H-D Stage-1 models, factory-installed?
0 Battery Life
Last Post: Four Speed
0 Choppin' Cotton
0 Help With Oil Flow
Last Post: IronheadPhil
0 Wheel bearings
Last Post: cotton1
0 Home servicing.
Last Post: dtkf
0 19 years and counting
0 Lost kicker stroke, is it normal?
Last Post: Pezed
Last Post: RKN
0 C.O.B.B run west
Last Post: Dustpan63
0 Spokes or Mags
Last Post: tomaso
lostNdallas's Avatar
lostNdallas lostNdallas is offline
lostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond repute
Default watch what you ask for...
you might get it.
So a week ago after I got done with the top end rebuild on my bike, my rear exhaust pushrod tube was leaking. I was lamenting having to deal with taking apart the rear cylinder since it's tight quarters. I told a couple people it would have been easier if it was the front cylinder since there is a bit more room to work with in the frame. 250 miles in to the break-in period, I notice some oil pooling on top front of the cam box. I got what I asked for. Last night I had to tear apart the front cylinder and replace the o-ring that I cut during assembly that didn't leak for 250 miles.
That said, I was able to finagle the front and rear cylinder heads individually without needing to remove the exhaust pipes. It now takes me a hair under 3 hours to pull the head starting at putting the kickstand down to connecting the fuel line back to the pump.
The journey IS the destination. (L-1,C-1,R-3)
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Year: 2014
Yeah you get good at it. I've had push rod tube leaks after a rebuild till I learned how to put the lower o rings in. They are the ones I had trouble with but not any more.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
The first leak was a lower and was cut through the cross section. The second was an upper and cut around the circumference, probably why it took 200 miles to start leaking.
