Last Post: randy3934
0 Any Teamsters?
Last Post: Knuckles
0 Big bore Stroker problem
0 Gear Spacing Question
0 New oil tank
2 My 1275 Hammer Conversion..
Last Post: Bryan1976
0 Bike wobble question
0 One More Ohio Meet & Eat?
0 How Do I Install An Inline Fuel Filter (Carb Model Rubbermount)
0 ADVICE?Is it supposed to look this cool or am I running lean?
0 Fyi
5 about the 1999 Sportster Right Fork converting to dual brakes
Last Post: salmanmr
0 WTB: Mainshaft Thrust Washers
5 Favourite grips?
0 Any wealthy forum members?
0 Stock vs. Modified
0 Forward controls
Last Post: jsandidge
0 Iron Mike Comment on WTB/WTS Parts
3 86 To 03 HD Forward Controls, Modified To Fit 1980
0 too much oil in primary
0 Oil leak
0 1969 Shifter shaft bushing
jdhickm (85), Chip (72), Chief4x4 (70), willyobiker (68), CBryant (67), XLCH69 (64), sage (61), Butch (61), VettesRule (58), jerseyjeff (58), TheExecutioner (55), SalTheWop (55), manic_mechanic, pauldmedic16 (46), BluegrassXL (42), Superman
Old 4 Days Ago
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished road
Originally Posted by Snowplow View Post
yeah been starting the bike a few times lately without running it long and it was just above freezing in the morning so im not suprised its a bit low. battery is new tho. was mainly looking at the voltage regulator.
Unless the bike gets to full operating temperature, you aren't doing it any favors.
Put fresh oil in it, charge the battery on a tender, and leave it alone.
Sent from my Moto E (4) using Tapatalk
Old 4 Days Ago
I was more impressed at 14.2 at idle, both my Cycle Electric systems on the "rubbers", wont see that until 1,300-1,500 r.p.m. Factory systems won't show that till near 3,500 r.p.m.
Old 4 Days Ago
There is no crank position sensor on a 1996 model is there?
No Crank Sensor - They came on 2004-later models & eliminated the visual timing hole. Computer (ECM) programming for timing after that.
Most of us eliminate the Vacuum Petcock by using a manual one - I'm not sure if you meant that or you're planning to put another Vacuum Petcock on it? Of course, you still need a vacuum hose to the VOES (not leaking).
A mangled vacuum petcock can drain fuel down the vacuum hose into the engine at the vacuum port on the carb (above/behind the throttle plate).
By the way, does the bike start without using the enrichener? That's a sign of extra fuel getting thru somewhere. Did you tune the carb? Does the carb have Dynojet parts?
Check out the Sportsterpedia CV40 Tuning page - It identifies Dynojet parts - and explains the workings of the various functions in the carb:
http://sportsterpedia.com/doku.php/techtalk:evo:carb02
Someone recently had issues due to the Enrichener cable (sheath) not seating properly.
Old 4 Days Ago
sportsterdoc's Avatar
No, there is a cam position sensor under the nosecone cover.
Old 4 Days Ago
Snowplow Snowplow is offline
Sportster/Buell Model: XL1200
Snowplow is an unknown quantity at this point
I was going to buy a vacuum petcock but seems like a simple manual one might be a better choice. less to fail in the future. Dont think it draws fuel down from the petcock as its not running rich. more the opposite. it starts to sputter and then dies when constant throttle is applied when warm or i go downhill enginebreaking then when i apply gas it sputters and dies. It starts right up again within 30 seconds and runs fine at idle then.
It definitely needs enrichner when cold but runs without it after a minute or so idling. Runs in everyway fine until it gets warm and at a constant throttle. id guess 2500-3500 rpm.
Dont want to mess with the carb until i have eliminated other possible causes but have dismantled and cleaned it.
Old 3 Days Ago
As you already planned, find out the condition of the vacuum hose & other vacuum related items...
After warm up, can you create this issue while parked & raising the engine speed to 2500-3500 rpms?
Since you're convinced it is heat related, you might try getting some cold spray to cool down the coil after the problem occurs to see if that changes the problem --- or opening the nosecone (round cover with rivets) to see if cooling that (with cold spray) affects the problem...
Let us know the results of those efforts...
