Last Post: brianbbs67
0 1998 883 spits and sputters at around 3000 rpm
Last Post: Tommr
0 Chinese S&S carbs
0 HD Museum Video - 1968 IH Dragster by Tom Reiser
0 clutch issue
Last Post: zack2267
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 2009 883
0 "S" model specific Q&A
0 Range With EFI 3.3 Gal Tank
Last Post: Counter Steer
0 Valve keepers won't come out
0 old style fender skirted
0 What's your road name? How did you get it.
0 Sportsterpedia Progress
0 Pushrod o-rings gaskets question
Last Post: gravelman
0 Ground Up Beginner Build
Last Post: commando57
0 Turtle tank on '79 frame
Last Post: Ted Town
0 Coil polarity
0 Do you use a bike cover?
Old 31st May 2020
wedge's Avatar
wedge wedge is offline
I would avoid anti seize on plug threads. If you get sloppy it shorts out the plug. Standard 30 wt oil is what I have been using since the mid 60's when working for VW. That was the factory method for keeping the #3 plug from seizing in the head (last cylinder to get the air flow and that plug was well known for seizing.)
Old 31st May 2020
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Street XG500
RDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond repute
Wedge, that's a good idea.
*Silver '05 883C Miss Molly* *Purple '02 883C Robin Marie*
Old 31st May 2020
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond repute
i just put in a set of ngk dcpr7e plugs.
i set the gap to .040
the factory plugs were starting to rust a bit.
bike has almost 5k miles.
they will be replaced every 5k miles or so.
i did not feel any difference in performance.
i dont track mpg.
i did put a tiny bit of anti sieze on them.
next time i might try oil instead?
the old ones looked fine, i saved them for emergency spares.
Old 31st May 2020
wedge's Avatar
i dont track mpg.
You won't use the old plugs, I swap mine at 5000 mile intervals too. NGK DCPR7E (or 8E if the engine needs them). No need for Iridium when you swap them out regularly.
Old 31st May 2020
Bryan1976's Avatar
Bryan1976 Bryan1976 is offline
Sportster/Buell Model: 1275 Sportster
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 1998
Bryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond repute
Hear that loud and clear! Use the same method on my 72 super beetle. Only use oil on the bike spark plugs as well.
Blue collar knuckle buster. Some call me slow Stroh. The people I work with call me G.S.D.S. They say if you want it done right , you better send G.S.D.S
Old 1st June 2020
No point not using anti-seize when you have nice unobstructed access putting the plug(s) in. Plugs are plenty easy to replace on a Sportster without getting anti-seize on the center electrode or the insulator tip.
Old 1st June 2020
wedge's Avatar
I know someone who said that once.
He had plenty of time to rethink that approach as he sat by the side of the road. (Actually there were two or three of us and there were spare plugs in the group).
I also had a situation once where we replaced plugs on a Honda 4 cylinder bike, then realized that we forgot to check compression. Those plugs had all been turned in by hand almost to the bottom of the threads using anti seize. BUT, when we pulled them to do compression, one plug was galled into it's hole to the point that it removed threads as it came out. So I'm not a fan of anti seize at all.
I use it for brake sliders, contact points on backing plates, back of pads for anti squeal too, and on steel threads into steel, but I avoid it on aluminum threads.
