0 Saturday Sportster Season 2
Last Post: PoodlePunche
0 Electronic ignition or points?
0 Riding with Diabetes
0 1999 1200S Sport ignition
Last Post: porkchop3583
Last Post: Turbo Sporty 48
0 Running Errands, Long Way Home
Last Post: bagster guy
0 Chrome
Last Post: Ted Town
0 Allegheny 2023
Last Post: joes95bobber
0 Air Filter
Last Post: br549arkie
0 New budget bar bike build
0 It's been a great Ride!
0 Bad Speedometer or Bad VSS?
0 Loco's Garage Sale
Last Post: LocoLocal
0 Torque is never enough
Last Post: conv90
0 stroker pistons found
Last Post: rocketnorton
0 Touring on A Sportster
0 Bendix tips
0 Need a rear fender
Last Post: 1skullster1
OKsporty (70), humpbackbob (69), Sunnydazepleaze (61), dvsxtc (58), elmo (46)
Old 27th November 2022
onadraw's Avatar
onadraw onadraw is offline
Sportster/Buell Model: XLH883/1200
onadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond reputeonadraw has a reputation beyond repute
Default Nosecone Timing Cover
I guess it's just my opinion. I turned mine sideways. I know it don't look right but I hate that the timing cover is supposed to be riveted in place.
Am I alone on this?
- Thou shalt not bow down and worship nor serve the God of Chrome; for, lo, he is a false god and will not get thy butt home.
1Scooter 1Scooter is offline
1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of
The timing cover is riveted on from the Factory so it's "tamper proof," in accordance with the EPA Regulations. HOWEVER, those rivets and the "tamper proof" carb mixture screw plugs have been removed on damn near every Harley out there. Turning the Timing Cover "sideways" makes me wonder. How did ya line up the screws to put it back on? OEM is top and bottom. Sideways is left and right.
onadraw's Avatar
The rivet holes are side to side. I rotated it and used the holes in the up and down orientation causing the "5" to lay sideways.
Just swap to an aftermarket cover, chrome or whatever and it'll look right.
Or you can get some HD rivets and put it back stock.
edit:
You could use self tapping sheet metal screws with Loctite to mate the inner and outer covers too.
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
I used a 8-24 (or 10-24) tap and tapped the holes, then used some Allen head cap screws.
Also, must again give thanks to member Tim the Grim for making the timing cover for me from a belt buckle. Eternally Grateful!
I do have a couple Harley rivets if you want to just use rivets, will send for free if you're interested, just PM your address.
John
onadraw's Avatar
John
Thanks for the offer but I don't want to rivet it. I might tap the original holes like you did though.
Old 30th November 2022
+1 mr. john
i attached mine via ss screws also
the rivet needs to be a blind rivet if you use them so water stays out.
Old 20th January 2023
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
You can take the plate and drill and tap the holes where the rivets vent and use screws. I did it but later on I put an AMF era points cover that had the holes vertical.
Old 21st January 2023
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
I bought a timing cover with vertical holes. Problem solved…
onadraw's Avatar
Cool
