0 Clutch release mechanism
Last Post: forqueue
0 Down on oil
Last Post: Whitewalls
0 1968 xlch
0 Oil leaking
0 Fuel Sputter & Much More
Last Post: AntsBAC
0 magneto twin plug heads
Last Post: Virto
Last Post: XL Dane
0 Boring intro
0 Nothing to See/Hear
0 THE Hockey Thread
Last Post: maltesefalcon
Last Post: FiftySixer
0 Your Favorite Style
Last Post: solorichard
0 XLF roadside assistance smartphone app?
0 H4 LED Conversion - write up with photos
0 Mounting seat
0 Chinese S&S carbs
Last Post: Joe_jeep
0 Clutch Q
0 Help identifying brakes
Last Post: bobandy
0 weld on hardtail
Old 3rd April 2020
Gazotenekes Gazotenekes is offline
Sportster/Buell Model: 883R
Gazotenekes is an unknown quantity at this point
Default Lifters+w cams
Hello,i wish health to everyone. I was getting a lot of ticking noise from my 2006 883R.Yesterday i changed lifters(hylift Johnson) and i upgrade my cams from D to W.Pushrods and everything was clean inside the motor, but i still hear a bit of ticking noise from the heads.Is this a normal thing for harley motors? Thanks everyone.
Old 3rd April 2020
harley506d's Avatar
Sportster/Buell Model: 1200c
Probably just the rocker tick that quite common. Mine does it.
Take a look at DK's rocker lockers.
http://www.dkcustomproducts.com/rock...s-c215-231.htm
Old 3rd April 2020
I installed them about a year ago!!
Old 5th May 2020
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
Sorted? Was it the "normal" ticking or something else?
Old 5th May 2020
brixtonanima brixtonanima is offline
Sportster/Buell Model: 883r
Other Motorcycle Model: Excelsior Henderson
brixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond reputebrixtonanima has a reputation beyond repute
What ignition are you running with the W cams?
Old 5th May 2020
I run my oem ignition.I haven't sorted out and i never will.I have done these things and the bike is still noisy.I'm tired to spend more money and time for a bike with technology from the 40s.
Old 9th May 2020
60Gunner's Avatar
60Gunner 60Gunner is offline
Rocker lockers work for their intended purpose and do cut down the common ticking associated with the rockers/bolts.
Johnson Hylifts are great lifters and cheaper than S&S, Fueling, or any other premium lifter. I use the 2313SE with directional oiling in my 103". Harley actually used these briefly til going elsewhere to save money. Go figure.
https://live.staticflickr.com/65535/...c4672303_n.jpg
Old 9th May 2020
LLOYD883's Avatar
LLOYD883 LLOYD883 is online now
Sportster/Buell Model: xl883c
LLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant future
When I changed to W cams I had to change my ignition module because of timing issues due to higher cranking pressure. I installed the Screaming Eagle XL1200 module 31785-04 which completely resolved the ignition timing issues.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
I switched from amsoil synthetic to spectro mineral 20/50 and there is i big difference on ticking noise.
Folkie Folkie is offline
I wouldn't worry about trying to eliminate a noise that is normal and to be expected with a pushrod engine. Bikes are noisy, and there are worse noises than the music of tappet chatter.
