Last Post: mikejosh212
Last Post: frank b
Last Post: mazmaz
0 Clutch release mechanism
Last Post: forqueue
0 Down on oil
0 1968 xlch
0 Oil leaking
0 Fuel Sputter & Much More
Last Post: AntsBAC
0 magneto twin plug heads
Last Post: Virto
0 Boring intro
0 Nothing to See/Hear
0 THE Hockey Thread
Last Post: maltesefalcon
Last Post: FiftySixer
0 Your Favorite Style
Last Post: solorichard
0 XLF roadside assistance smartphone app?
0 H4 LED Conversion - write up with photos
0 Mounting seat
0 Chinese S&S carbs
Last Post: Joe_jeep
0 Clutch Q
0 Help identifying brakes
Last Post: bobandy
0 weld on hardtail
Old 4th July 2020
wedge's Avatar
wedge wedge is offline
Originally Posted by supermotolew View Post
Warmed the coild today readings changed is this dead ?
Cold
3.5ohms side terminals
17.1 k ohms HT side
HOT
3.9- 4 ohms
19.1K OHMS
Sportsterdoc is more versed on the readings, so he needs to see this. Personally I would suspect that the coil is bad from the changing readings, plus they start out higher than he said they would be.
Old 4th July 2020
i agree the resistance is higher which is not good but i would expect to see an open circuit when hot indicating no readable resistance.
A functional test when heating with the hair dryer may be more definitive. Intermittent operation may be created under load even when it appears relatively OK with no load.
I would heat test it when properly wired up while the engine is cold. See if the same failing symptoms occur immediately or before the engine fully warms up.
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to behold
How's your pushrod adjustment? Tight pushrods will get tighter as they heat up and you'll lose all your compression. When cooled down, it's normal again until it gets hot. Easy way to check is to go for a ride and when the motor quits, pull a spark plug wire and see if it will arc when you try to start the motor. If you have spark, it's not ignition related.
Eric
supermotolew supermotolew is offline
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1984
supermotolew is an unknown quantity at this point
So last night i couldent even get it started anymore i removed a plug and cannot see a spark when grounded on the head. I did get 1 backfire while trying to start and about 20 seconds of idle though maybe its intermitant. Or very weak. Id be intrested if anyone knows anything about those coil numbers i got. I did notice the coil was very slightly warm but i was outside in the cold. After warming with a hairdryer it gave same numbers as my hot test.
Ok its beat me i think ill save for the uktima kit for sure best price uk i can see is £235 so $300 ish. I cant find an exact manual listed for what i think is the model i need( 53-660 ) but ive seen some utima manuals online that look very simmiler when it arrive will post back regarding timing withought Voes and what map to use.
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
JonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond reputeJonesL has a reputation beyond repute
My 2 cents worth; I've had best luck buying factory, especially with electrical components.
If you go for a replacement coil steer cleer of made in china/made in taiwan stuff.
I'm not above updating and have a Dyna S in my '71. It's been a set it and forget it change-over from points and condenser.
If you hear hoofbeats-- think horses, not zebras.
sportsterdoc's Avatar
Lower than spec resistance on a coil is likely a partial short...that is a section of windings are bypassed, which could reduce coil output.
Higher than spec resistance on a coil can be caused by:
a. Corrosion on an internal connection
b. Poor contact with VOM probes
If a, could reduce coil output
If an open coil, infinite resistance, then no coil output.
To decide if coil and/or ignition module:
1. Verify good voltage to coil primary, typically connected to + side (coil has no polarity, but that side is battery voltage)
2. Disconnect - side to ignition module. Jumper - side to ground. With coil energized, disconnect jumper to ground and there should be a spark to a spark plug (cable connected, prong properly grounded).
If the coil functions, if connections are good, then the ignition module has failed/is failing.
