0 Down on oil
Last Post: Whitewalls
0 1968 xlch
0 Oil leaking
0 Fuel Sputter & Much More
Last Post: AntsBAC
0 magneto twin plug heads
Last Post: Virto
Last Post: XL Dane
0 Boring intro
0 Nothing to See/Hear
0 THE Hockey Thread
Last Post: maltesefalcon
0 Clutch release mechanism
Last Post: Rioo
Last Post: FiftySixer
0 Your Favorite Style
Last Post: solorichard
0 XLF roadside assistance smartphone app?
0 H4 LED Conversion - write up with photos
0 Mounting seat
0 Chinese S&S carbs
Last Post: Joe_jeep
0 Clutch Q
0 Help identifying brakes
Last Post: bobandy
0 weld on hardtail
  #41
Originally Posted by thefrenchowl View Post
earlier i thought i saw bronze bushing material accumulated at the oil pump drive gear,but if this is the XLRTT it doesn't use bronze bushings in the cam cover but roller bearings?
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Model #2: IronHead XLH
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Only one brass bush left in there, the big one on the outside of cam #2, rear intake, where the rev counter drive replaces magneto or timer...
It can be straight replaced either with a ball bearing or a Torrington needle bearing, but I am not that bothered yet!!!
All the shinny bits in there are castor oil reflections...
All the best from Patrick
Flat Head Forever
so you still have the '66 XLRTT,cool!
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Most of the guys on here won't have seen an engine run on castor oil.
But they will have seen the bottom of a stainless steel frying pan that's had some cooking oil heated in it.
i can still remember when 2 strokes burned it with their gas.'60's 70's. bean oil.
Blind Owl
There are still a few "holdouts" in the Manx Norton Brigade running Castrol R. I get a faint whiff of it walking through the pits every now and again.
40 years ago virtually everyone racing used it.
kitabel kitabel is online now
Sportster/Buell Year: 1989
kitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to behold
IIRC beginning with the WR the #3 & 4 cover bearings are the same R6 ball bearings as the inners (the #1 is the pump drive).
The KR onward uses an R6 in the #1 position also.
Blind Owl
These are the cases I have alonng with the sump casting.
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
"R"
My buddies with RD's were using bel-ray synthetic
the bean burned dirty and the mixture ratio was skinnier than other oils so I put slack in the cable to the oil injecter on my '74 kawasaki. My 18 year old scientific method
I never knew it could be used in crankcases
Never forget that smell
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertramp 2/2
