Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Organize a Group Buy
Organize a Group Buy Here is where you can organize a group buy. Anyone can organize a group buy to include commerical vendors. This is only section that non-supporting vendors may mention their products but only in conjunctions with a group buy.
0 oil filter stuck
Last Post: Bikeaholic
Last Post: BestCoastXL
0 New Lifters with new cams with your conversion?
Last Post: yelladox
0 S&S Super E
Last Post: RussW
Last Post: TPEHAK
0 Ia 83 xlx
0 is a buell a harley
0 883 rev range
Last Post: ConRich
0 Hawkeye's 1275 Hammer Performance Conversion
Last Post: hexnut
0 how to reduce buffering
Last Post: Stude
0 Sidehack for XLS
0 yost power tube guy
0 Proper XLCH
Last Post: revjen45
0 73 xlch gas flowing from carb
0 passenger with driver's backrest
0 Iron 1966 XLRTT
Last Post: xlerate
0 Your Favorite Style
Last Post: AZbiker
Last Post: Marsikus
0 Chain drive vss
Last Post: jon1966uk
0 1983 Ironhead - Oil not Returning
Old 9th March 2018
rocketmangb's Avatar
Default Air Filter Elements for Hammer or NRHS housings
OK gang !
I'm going to order a special build air filter for the OVAL shaped 3" high filter from K&N
This is a true oval on both sides as opposed to being a Tri Oval on one side like supplied with the housings.
I understand its a matter cost so it uses an off the shelf unit.
The custom filter would run about $100.00 shipped more than 10 would run about $80.00 shipped
The standard replacement HD2076 runs $50.00 depends on vendor.
Any interest send me a PM
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 2nd April 2018
Bump it up bump !
Old 2nd April 2018
mikeLI_77's Avatar
What is the benefit to this?
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Old 2nd April 2018
Mike
This fits the housing better in my opinion
It uses the same mold on both sides unlike the HD 2076 filter you have now
