0 1970 XLH smoke from rocker box gasket
0 S&S Super B help
Last Post: Randy_rots
0 Iron 1966 XLRTT
0 What’s your take on Harleys ceo putting down the sportster line
Last Post: AZbiker
0 yost power tube guy
0 Ironhead Exhaust Poll
0 S&S Super E
0 Swing arm bearing change
0 I made a oopsie
0 oil filter stuck
0 Sidehack for XLS
Last Post: Serious Blac
0 RIP Trainman
Last Post: 83XLX
0 1970 XLH Tach cable kinked
0 Changing stock air cleaner to aftermarket
Last Post: 83XLX
0 Why cafe a sportster?
0 What to do now? Ironhead clutch hub nut stripped
0 Homemade Lithium Battery
Last Post: t120r
0 Bolts and Metal Type
Last Post: BigMek
Old 25th February 2021
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
Default Change to UK petrol
Hi,
a bit of information for my UK brothers & sisters.
I've just been reading an article that the government are getting the oil companies to change the petrol in the UK to E10 from E5 later this year, meaning they are putting more ethanol into it, which is bad news for old engines.
E5 is going to be branded as a 'super fuel' & they'll be charging more for it.
Hope you find this useful.
Andy.
Old engines do not have problems with ethanol. In fact they run quite well on it.
The problem with ethanol in pump gas is the water content.
Older fuel systems may have rubber parts that are not compatible with ethanol.
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
I filled up my bike using a container of "hurricane gas" I had stocked up last year.
I usually put stabilizer in, must have forgot this can.
Had to empty my bike tank, looked like pure water. Drained carb, pulled plugs and spun the water out the cylinders.
I poured the last gallon out the gas can and it was like pure water.
Lucky she died in my driveway right after filling!
Steve
'01 Cyclone
'13 FXDC 96" stock
Folkie Folkie is offline
I hope we can still get posh petrol ('Supreme', 'Advance', etc) with no Ethanol at all?
wiltybob's Avatar
wiltybob wiltybob is offline
Sportster/Buell Year: 1983
Sportster/Buell Model #2: xlh bobber
Sportster/Buell Year #2: 77
Other Motorcycle Model: xlh hartail
Other Motorcycle Year: 79
wiltybob is an unknown quantity at this point
forgot what make it is but the petrol station i use still sells ethanol free fuel. its eay enough to remove anyway if problems arise
42...the meaning of life,the universe and everything
NLXL's Avatar
NLXL NLXL is offline
Sportster/Buell Model: XL883DLX
Here we have E10 and E5. The E10 should have 10% alcohol in it. The E5 should have no more that 5% in it. The companies who sell E5 here don't even put 5% in it. That's too costly it seems.
Strange enough you have to pay more for E5 up to 10 Eurocent per liter.
Sportsterpedia
Ethanol costs twice as much to produce as gasoline.
Here in the states ethanol is stored in vented rail cars. No protection from water absorbtion.
You may be able to get non-ethanol fuel from a marine dealer.
