0 WTB 04-06 intake manifold
Last Post: beardo
0 I made a oopsie
0 1970 XLH smoke from rocker box gasket
0 S&S Super B help
Last Post: Randy_rots
0 Iron 1966 XLRTT
0 What’s your take on Harleys ceo putting down the sportster line
Last Post: AZbiker
0 yost power tube guy
0 Ironhead Exhaust Poll
0 S&S Super E
0 Swing arm bearing change
0 oil filter stuck
0 Sidehack for XLS
Last Post: Serious Blac
0 RIP Trainman
Last Post: 83XLX
0 1970 XLH Tach cable kinked
0 Changing stock air cleaner to aftermarket
Last Post: 83XLX
0 Why cafe a sportster?
0 What to do now? Ironhead clutch hub nut stripped
0 Homemade Lithium Battery
Last Post: t120r
0 Bolts and Metal Type
Last Post: BigMek
  #101
Old 31st July 2020
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
I’d have to see your rulebook as to their wording. Does each spigot count as a point of attachment?
Old 1st August 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Yes, they count, so one in the middle and one at the rear make the three points. I could add 10 more if I thought it would help and I could find some place to do them.
Mind you, the large hose clamps have been fine so far.
Old 1st August 2020
Scott Scott is offline
Sportster/Buell Year: 1981
Sportster/Buell Model #2: Sportster with sidecar
Other Motorcycle Year: 2002
One of the cool things about this bike is that no one will ever know what it is. I thorough explanation would overwhelm most people. You might get "Nice Harley. My uncle had one just like that." In high school, any motorcycle you ride in on will put you on top of the coolness mountain, let alone a fuel injected ironhead.
Old 25th February 2021
Jimmy Buffett came by today, gave me a little inspiration to work on the shit box special. Fins to the left.
Still have a bit of refining to do, it can wait until tomorrow to run the preheat sequence again. Nothing a little more filler rod and some paint can’t fix up.
All done with some donor cylinder fins and the tig.
clavier visuel en ligne
Works good.
It looks amazing. Nothing shit-boxy about it. Hats off.
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
You done good.
Looks as straight and clean as possible.
Steve
'01 Cyclone
'13 FXDC 96" stock
Nickel rod.3/32''? i have some myself in 1/8'' and 5/32''.nice job fitting them in.
Thanks for the compliments guys. Still needs some finishing. Most of the fins in the pics are still about 3/16” or so too long. Most of the exposed joints that are not filled will be ground smooth. Should look half decent when painted and finalized.
You got it Bruce. That’s the rod. Cleanliness and temp control pre and post is crucial with cast. Small toaster oven was used for preheat, and big fiberglass blanket helped out controlling the cool down.
(Hey Scott, just noticed Jr’s flat tracker photo bombed the pic of the rod. Behind the big XR front end lurks the little XR 100 based slider!)
