0 yost power tube guy
0 1970 XLH smoke from rocker box gasket
Last Post: Rolschnee
0 Ironhead Exhaust Poll
0 S&S Super E
0 Swing arm bearing change
0 I made a oopsie
0 oil filter stuck
0 Sidehack for XLS
Last Post: Serious Blac
0 RIP Trainman
Last Post: 83XLX
0 1970 XLH Tach cable kinked
0 Changing stock air cleaner to aftermarket
Last Post: 83XLX
0 S&S Super B help
0 Why cafe a sportster?
0 Iron 1966 XLRTT
0 What to do now? Ironhead clutch hub nut stripped
0 Homemade Lithium Battery
Last Post: t120r
0 Bolts and Metal Type
Last Post: BigMek
0 Oil pressure stays up 20min after shut of
Old 19th February 2021
Billy1200's Avatar
Billy1200 Billy1200 is offline
Sportster/Buell Model: XL1200 C
Other Motorcycle Model: Xvs650 dragstar
Billy1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to behold
Default Shocks and clutch Q
Put this post here as it's two part..
Fancy dropping the arse end on my bike maybe an inch are the lowering kits advisable ? Reason I ask is it looks like the angle of the shocks using them may put undue stress on shocks due to the angle they sit at ...
Or " better" to buy shorter shocks ?
Secondly
Thinking of changing clutch pack as I'm not sure if mine still has stock grenade plate but not keen on spending silly money ..
Iv used EBC clutch plates on all my bikes in the past and been happy with them ..
i can buy 2 sets of EBC friction plates and 2 stock steel plates for a fraction of some of the extra plate sets ..
Any reason why doing it this way won't work ( can't see why myself but thought would ask)
I know I would have to keep an eye on overall thickness of pack etc to make sure all fits ok ..
Cheers
2002 XL 1200C
BKB's Avatar
BKB BKB is online now
For the clutch, most here will recommend just getting the stock plates to get rid of the grenade plate. The shocks depend on your weight. My wife weighs about 150, rides a 1200Low. The stock 11.5"shocks were too stiff for her weight & hurt her back on good roads. We put on a set of stock 13.5" shocks (lighter springs), with a pair of lowering blocks to maintain the stock ride height & all is well. I weigh 175 & when I ride her bike, the only time it bottoms, is a very bad bump at speed. If you weigh more than I do, I'd say get some shorter shocks, as they will have stiffer springs for the weight. You're still giving up suspension travel, no matter which way you go. If your roads are are good where you are, that shouldn't be a big deal.
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I put Progressive 11" shocks on the rear, also lowered the front forks 2"
Old 25th February 2021
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud of
It doesn't stress the suspension, but it will make it ride softer. The more the shocks "lay down" the softer the ride. The closer they are to vertical the harsher the ride.
I don't think the solid mounts had the grenade plate, but I could be wrong.
Sent from my Moto E (4) using Tapatalk
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond repute
I replaced the spring plate in my 07 883 with appropriate stock plates. I like it. No difference that I can tell.
as for rear shocks, no comment, my 79 Shovelhead FX had alternate mounting points welded to the swing arm, the shocks were "laid down" a tad, bike was thus lower, Never any issues, I guess I was used to it.
I weigh about 200 with helmet, boots and jacket etc. I would guess. My shocks are on lowest setting, haven't bottomed yet.
Air-cooled Forever
Shock lowering blocks is the cheapest route. I think that as long as the shocks aren't more than 45 degees, there really shouldn't be a stress factor to worry about.
