0 I made a oopsie
0 1970 XLH smoke from rocker box gasket
0 S&S Super B help
Last Post: Randy_rots
0 Iron 1966 XLRTT
0 What’s your take on Harleys ceo putting down the sportster line
Last Post: AZbiker
0 yost power tube guy
0 Ironhead Exhaust Poll
0 S&S Super E
0 Swing arm bearing change
0 oil filter stuck
0 Sidehack for XLS
Last Post: Serious Blac
0 RIP Trainman
Last Post: 83XLX
0 1970 XLH Tach cable kinked
0 Changing stock air cleaner to aftermarket
Last Post: 83XLX
0 Why cafe a sportster?
0 What to do now? Ironhead clutch hub nut stripped
0 Homemade Lithium Battery
Last Post: t120r
0 Bolts and Metal Type
Last Post: BigMek
Old 3rd March 2021
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Default Need Tuning Advice "E"
Just got my knockoff S&S
'81 with Andrews "Y" cams
Which jet should I start with?
Advice appreciated
Steve
'01 Cyclone
'13 FXDC 96" stock
Old 3rd March 2021
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
On my 72 with a genuine Super E I run .0295/.068 jets. Tear drop AC and muffled pipes. Runs well.
[IMG]http://i.imgur.com/Oe4Ttw0.png[/IMG][IMG]https://i.imgur.com/AFv3AMo.jpg?1[/IMG]
Old 3rd March 2021
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
brother go with 29.5 and 68 main.works great up here in the mountains,and down the hill on my street stroker.on the mixture screw,start with 1 1/2 turns out and go down,leaner from there.turn it in till it starts to run bad and turn it out a 1/2 turn.mines with r5 cams.good luck with this chinee knockoff
Old 3rd March 2021
Steve9's Avatar
Thanks brother
I'm at sea level, that matter?
Good to see you
Old 3rd March 2021
SHAKY DAVE's Avatar
that's why I said down the hill.you get your mid controls straightend out?also make sure you run a carb support and setting up the enrichener with an s&s air cleaner complete with with the inner and enrichener gadjet
Old 3rd March 2021
Steve9's Avatar
Roger
Still kicking the shifter straight up. Rear brake should be next week
You know how stuff goes
Thanks for the start point!
Old 3rd March 2021
Sportster/Buell Year: 1969
Both my Ironheads are outfitted with genuine S&S Super B carbs. Both have 295/68. Both are modified engines.
