0 Intake manifold gasket fitment
Last Post: BlackBettyXLC
0 Hillbilly Hot Dogs
Last Post: BSA Bob
0 Anyone know how to stop the ads from coming in from the right side of this page?
4 Occasionally running troubles
Last Post: jcro61
0 My last real nagging problem
Last Post: Keep it running
0 Oil Pump upgrade
Last Post: hotrodbiker
Last Post: wongjohnson
Last Post: Ridneck1986
0 Xl/Buell drag bike parts
0 The country store
Last Post: lugster
0 XR1000 carbs Dellorto
0 Lost compression?
Last Post: semjpm
0 TC88A and Raptor shift light
Last Post: AnaChris
0 1995 Odometer Acting Strange
Last Post: JackFrost71
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: NZstu
0 2014 Sportster 48 $5500
Last Post: ChaseN
0 Carb issues
0 Am I missing a front wheel spacer?
Last Post: jharback
0 Oil On Underside Of gas Tank
0 Stuck in fist after a spill
Last Post: amfxlh
0 Removing powder coat?
0 Spokes or Mags
prbetts (71), 1988XL (67), jbcant (66), gearman (63), rejeanprimeau, Hdrider8831200 (57), AOW (50), adair727, Mechano (46), 64physhy, Buckshot (44)
Old 29th October 2007
drhooligan's Avatar
drhooligan drhooligan is offline
drhooligan has disabled reputation
Default 2nd conversion
I currently have an 05 883/1200 conversion with the SE stuff and 497 cams with stock 05 883 heads. Have access to a set of 05 1200 heads(black highlighted fins) for very cheap.
I love the look of the black engine and highlighted fins of the factory 1200s. I'm considering buying a set of stock 1200 highlighted jugs and 1200 pistons to use with the heads. The stock pistons I believe are 9.7:1 CR. Would like higher. there is an SE piston (22711-04) that is 10.5:1. Would those workwith a .497 cam and the stock 05 1200 heads.
I am considering sending the heads to NRHS for a stage 1.
Any advice would be appreciated.
Rothlisburgh PA
ReddTigger's Avatar
Yes these would work.
I am going to be installing the .497's this winter and I'm already at 11:1
States I've Ridden in
71.3 hp 70.8 tq
drhooligan's Avatar
I'm not sure which pistons to use. The SEs are 10.5:1 and the stockers are 9.7:1. I guess the 497s would work with the 9.7 stock pistons. I wonder how much power would be left on the table by using the stock 1200 pistons.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
If your sending your heads to NRHS why not buy your pistons from them. The 05 1200 heads are extremely good heads. Since this is your 2nd conversion I would suggest going stage 2 on the heads now and maybe preempt the 3rd conversion. The stage 2 will cost a couple hundred more but you'll already be tore down and they will already have your heads.
