0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New England 2018
Old 11th January 2011
nrs_nate nrs_nate is offline
Sportster/Buell Model: 1999 1200 Custom
Sportster/Buell Model #2: 1998 1200 Custom
nrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enough
Default "Sandblast Chopper frame" what happens if you get it wet or oiley?
What would happen if your freshly sandblasted chopper frame got wet or oiley? Is this serious? Can it be fixed? Looking to powdercoat...
Thanks Nate
It will rust very quickly if it gets wet and will need to be reblasted to fix.
Oily is not an issue. Just degrease it very well before paint.
TinMan_4L's Avatar
TinMan_4L TinMan_4L is offline
Sportster/Buell Model: iron 883
TinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to beholdTinMan_4L is a splendid one to behold
Also if you dont have it somewhere away from the cold as the temp changes it will have condensation form possibly and that too will cause quick rust .....I found out the hard way :P Dry location if possible,even if it gets cold, as long as you can keep some air circulated on it till you get ready to paint .
A lot of folks will actually spray the entire frame with WD40 until they are ready to paint it. Just needs to be spotlessly degreased before painting.
Many drag racers actually keep thier frames raw steel. This allows them to see any craks much easier than if it was painted. they just spray it with WD40 about once a week.
While on the subject of powder coating, Should I mask the VIN number? or holes with threads in them?
Thanks Nate
Old 12th January 2011
kauffmanstein's Avatar
kauffmanstein kauffmanstein is offline
Sportster/Buell Model: Sporty Project
Sportster/Buell Year: 77
Sportster/Buell Model #2: 883c
Sportster/Buell Year #2: 2000
Other Motorcycle Model: Kawasaki F9
Other Motorcycle Year: 1972
kauffmanstein is an unknown quantity at this point
I would just chase the threads with a decent tap and some tapfree, I don't know about masking the vin. I had a base/clear paint job on mine and the vin is almost unintelligible, my guess would be powdercoat is as thick.
So much junk, so little time
Old 16th January 2011
flourman's Avatar
flourman flourman is offline
Sportster/Buell Model #2: XLCH Chopper
Sportster/Buell Year #2: 1962
flourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really niceflourman is just really nice
Desert racers do the same thing. When I lived in SoCal, I had a buddy with a rock buggy that kept the entire frame bare steel. After a weekend in the desert, he would power wash it, let it dry, then wipe it down with WD40.
