Last Post: gravydog
0 1972 tank fitment
Last Post: 72 Ironhead XLH
Last Post: Airbozo
Last Post: nibroc
0 going tubeless in pretubeless 9 spoke mags
0 Help me with gas cap...
0 Sportster or Street Bob
Last Post: joes95bobber
0 1977 xlch starter issues
Last Post: russzx6
0 Primary Oil INSANITY!
0 Lowell, MA weekly moto night (Tuesdays)
Last Post: tvon
0 Blues & Brews 2018
Last Post: tvon
Last Post: tvon
Old 16th January 2011
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
RivetHog. Having the Sprocket shaft shoulder NOT contacting the flywheel face makes sense since this ensures a full seating of the shaft. What few I've reassembled I just torqued the nut to 120 lbs., red loctite and the nut keeper. I'm not going to use this particular flywheel assembly in this build but I will do an inspection on this particular area. If you look carefully at the picture the outer shoulder is cracked inward, not outward which I think would be the case with shoulder interference/ shaft seating. Metal fatigue ?
thessler thessler is offline
Sportster/Buell Model: 1983 xls
Sportster/Buell Model #2: 2008 Goldwing
Other Motorcycle Model: 2005 superglide
thessler is an unknown quantity at this point
hcrashster
I get your drift I know the motor needs to come apart, I guess i'm hesitant because I don't have all those fancy reamers, or a press and I don't want to start buying tools that I may use once in a lifetime. I might just yank it apart today and stop messing around. I think it's going up to 32 deg today. Won't be bad if I work in the sun.
Tom
