Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Seating and Luggage
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 no rear brake light
0 Sportster or Street Bob
0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: 60weight
0 New member in MD
Last Post: xraytoken
0 Help me with gas cap...
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Cad Plating
Last Post: conv90
0 1968 XLCH Oil Leak
Last Post: 72 Ironhead XLH
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
Old 20th January 2011
Vegasmoon's Avatar
Vegasmoon Vegasmoon is offline
Sportster/Buell Model: Xl l
Vegasmoon is an unknown quantity at this point
Default The right spring soloseat kit for sporster 2004 xl1?
Hi there folks!
I am looking for tips on the right spring soloseat kit to fit this Sporster. The papers says it is a 2004 modell, but it might be a 2003.
Thanks
Vegas
Old 21st January 2011
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
That's not an '04, it's an '03: completely different.
Folkie
South East England Riders
Vegasmoon's Avatar
Thanks for info.! It is good to have it settled. One step closer.
Vegasmoon's Avatar
By the way Folkie. Any suggestions on how tu put a solo (springer) seat on this?
Thanks
Folkie's Avatar
Brass Nut
You could try Licks. I'm sure others will suggest other sources.
Basically it involves a hinge to support the front of the seat, and springs to support the rear. The hinge and the spring stantions are welded to the frame. Or were you looking for a non weld solution?
Vegasmoon's Avatar
Thanks Folkie. For me it would be best to avoid the flamethrower. So another solution would be better. Thanks for the answers!!
SuicideCharley's Avatar
SuicideCharley SuicideCharley is offline
Bike Builder
SuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to all
PM'd you. I got a solution but it involves welding , very simple and cost is about 15 American dollars. I can fabricate (check me out "fabricate" ) and send you a front mount like mine and send it to you at no charge, but someone would need to weld two mounting studs for the springs on the rear. PM me back if interested....I'll also be posting a thread on this after I finsih it up this weekend.
snake oil's Avatar
snake oil snake oil is offline
Sportster/Buell Year: 04
snake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nicesnake oil is just really nice
I got a bolt on set up off Ebay for $75 then bought a better seat from a salvage yard for $125
Folkie's Avatar
Brass Nut
But yours is a rubber mount, and he has a solid mount.
snake oil's Avatar
In the upper right corner of the post it says his bike is 04, so I assumed thats what he has.
