0 Oil Hose replacement help.
Last Post: McQueen
Last Post: jcro61
0 2016 48 Hesitating
Last Post: andy_t
Last Post: JensWest
0 Primary Oil INSANITY!
0 Tank swap
0 Fuel Pump Problems
Last Post: Blues
0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 FNG from OKC
Last Post: oreocat1
0 New From CA
Last Post: oreocat1
0 New in NM
Last Post: oreocat1
Old 21st January 2011
dointheton dointheton is offline
Sportster/Buell Model: ironhead-73/74 frame/eng.
Sportster/Buell Year: 73
Other Motorcycle Model: suzuki hayabusa
dointheton is an unknown quantity at this point
Default 'ham can' air filter on ironhead with cv carb
okay my newly bought ironhead has a evo cv carb with an air raid type filter on it. i want to convert it to an original style ham can oval filter. do i need an evo one, an ironhead one or parts from both to make one. anyone done this?
you can have my motorcycle when you pry my cold, dead fingers from the throttle.
80xlPaul's Avatar
80xlPaul 80xlPaul is offline
Sportster/Buell Year #2: 1973
Other Motorcycle Model: flhtc
Other Motorcycle Year: 1993
80xlPaul will become famous soon enough80xlPaul will become famous soon enough80xlPaul will become famous soon enough80xlPaul will become famous soon enough80xlPaul will become famous soon enough80xlPaul will become famous soon enough
I wouldn't want to restrict the air flow, most run a high flow filter with better pipes
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Not sure but I think you will find you need an Evo-specific air filter, it will have a notch in the top to allow clearance for where the diaphragm housing sticks out at the top of the carb body. But you could always cut a notch out the backplate of an Ironhead filter and weld a suitable filler in place.
I am getting confused between the filter itself and the air cleaner&backplate which is the housing that holds the filter. Anyway, the IronHead air cleaner backplate will not attach to a CV carb. So you need the Evo backplate and filter for sure. Not sure about the rest.
sorry wrong terminology. i meant air cleaner assembly. the evo style backing plate is supported on the heads by the air breather bolts. no such mounting on the earlier ironhead engines. the backing plate is also secured by if i remember correctly three allen or torx head bolts to the carb itself. i don't think used by themselves the carb bolts will securely hold the air cleaner assembly. how is the stock ironhead oval air cleaner mounted to the stock carb?
Here's a stock 70s A/C backplate ...
Note the indented part - the Keihin butterfly carb fits in there and is attached with three bolts; the CV carb will not fit into that indent. A support bracket attaches between the backplate and the front intake lifter block bolt.
I believe the outer cover may be the same?, so perhaps with a 70s trim plate it could retain the 70s look.
looks like evo it is with some other fabbed bracket to support for the weight of the air cleaner assembly. thanks for the pic and info.
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
Sorry Mick but dointheton is corect it is an evo as as late 70s early 80s is smooth all around with no horn like projection on the front side and more like a bread box in america or in england a bread bin . you are corect on early ham can only fiting on tiltson, bendix and kehien butterfly . cv carbs need an 88 and up style with the horn in the front like the new sportster have . Nikki
the difficult can be done immediatey the impossible takes a little longer
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
You need an Evo air cleaner assembly from '88, '89, or '90. These are the years with a CV carb and without the head breathers. All you need to do is adapt (or make) a simple support bracket for it. You could adapt a '91 or newer one, too, but you'd have to plug the breather holes as well as fab a bracket.
I'd look for one of the older Screamin' Eagle kits for '88-up...they used a nice, flat, high-flow aluminum backplate, an internal velocity ring, and a K&N air filter. All you add is a stock oval cover. Here's an '86-'87 Evo kit I adapted to my Ironhead, but for the earlier Keihin butterfly carb.
Sepixlh's Avatar
Sepixlh Sepixlh is offline
Sportster/Buell Model: XLCR-1000
Sepixlh is an unknown quantity at this point
You can combine CV backplate and butterfly backplate, here link to other site were I posted pics how I did conversion with Mikuni HSR42
http://www.hdforums.com/forum/4505960-post4.html
