24th January 2011
Posts: 187 Sportster/Buell Model: XL883C - Two Tone Blue Sportster/Buell Year: 2005 Other Motorcycle Model: Honda CM400T Other Motorcycle Year: 1980
Thanks for all the good advice everyone. All very sound judgments. My orthopedist is conferring with his colleges, and I will continue to search the internet for information. If there is no risk to me opting for no surgery, I'll do that. It may be slow healing, but I don't want to introduce further pain and suffering if there is no risk to me, other than slow healing.
Remember rubber side, down!
Wrench Head of the Popes of Hell MC
24th January 2011
Posts: 874 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2006 Sportster/Buell Model #2: X1 Sportster/Buell Year #2: 1999
I agree with you, opt for no surgery if you can wait. Be careful of the I will confer with my colleages. When that happen with me that was when they came back with cracking me wide open.
24th January 2011
Posts: 4,473 Sportster/Buell Model: 883-1250 Sportster/Buell Year: 1999 Other Motorcycle Model: 600cc CBR Other Motorcycle Year: 1987
It's good that the surgeon is conferring with his colleagues... but that should not be considered a second opinion... IMO. The point of getting a second opinion, is to find another competent doctor who has not been influenced by the original. If they are colleagues, most likely they will all have the same opinion. I'm not saying that it is wrong, but it wouldn't count it in my book as a second opinion, even though I would be glad that the doctor was conferring with his colleagues too.
Do some searching on the internet for a good hospital, doc, etc. in your area. I've usually just looked up the best ranking hospitals in my state and called the corresponding doc/department for an appointment or a referral.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
24th January 2011
Posts: 21,407 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
+1
Very good advice. Get an independent second opinion.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
24th January 2011
Posts: 1,159 Sportster/Buell Model: XL 883 Sportster/Buell Year: 2007
Just a thought off the beaten path on this thread. I had a major heart attack early this summer. I am now almost completely symptom free. Exercise and diet alone would not do this I have been down that path before. A friend brought me a Ionways Alkaline Ionic Water System and I tried it. It works by helping eliminate acid from the body and the filtered and modified water promotes healing very well as it is such a strong anti-oxident. In matters where healing needs a hand drinking this water will aid healing, even a ticker!
2007 XL 883 - 1/4 Harley Fairing - ISO grips and pegs - Mustang Vintage wide - Adjure Reflector & PIAA bulb - 50 State Mufflers - ABS front fender - Tail pack for stuff - HyperPro progressive fork springs - Whittlebeast rear shocks = Rocky Mountain Sport Tourer :-)
24th January 2011
I think you'd have just as much luck with praying to the sun god.
http://www.chem1.com/CQ/ionbunk.html
25th January 2011
Originally Posted by jharback
Well with regard to the water remarks, since we're carbon based entities, and 98% water, having a constant flow of H2O is a good idea, healing or not. I do have a whole house filter, plus an additional filter in the fridge, and there is a noticeable difference between tap water and water from my fridge. I make my morning coffee with the fridge water. I live in the North East, and the we have hard water. So I know the reduced iron, magnesium, other dissolved metals in my water is good for me, but my body will process those things I need from the water and disperse to my bladder those things that are bad for me.
So I am like minded that special water is only as good as the things in it or not. but I tend to shy away from gimmicks which attempt to separate me from my hard earned money.
25th January 2011
Posts: 12,192 Sportster/Buell Model: XL1200 R Sportster/Buell Year: 2006
A second opinion is a good idea. The question you should ask is what are the long term effects of a non healing bone fracture. If you re-fracture your tibia to the point where it will never heal, you may loose the ability to bear weight on it and not be able to walk.
Google alkaline diet, lots of information, including supplement pills you can take. Be careful, going too far alkaline or acid can be dangerous. You can buy Alkaline water by the bottle to see if it helps you before spending thousands on the filter. You can also buy alkaline drops to replace minerals removed from water filtered by reverse osmosis.
26th January 2011
The main reason I'm asking around is that my injury is 'slow' healing, not a 'non' healing fracture. If that were the case, it's an no-brainer regarding the surgery.
I'm a 'if it ain't broke don't fix it.' kinda guy. My leg is healing, just not as quickly as my Orthopedist would expect. So I've got a follow up with him next month, and we'll see what he says. Now I am noticing a change in my leg in this past week, I'm not using my cane at all, and I've got mild stiffness, but no pain. So I know its healing. I hope it's sufficient that I won't be left with surgery as my only option.
Thanks to everyone whose thrown their hat in the ring.
11th March 2011
Posts: 219 Sportster/Buell Model: Sportster 1200 Custom Sportster/Buell Year: 1987
Did the doctor put you on a diet? I have heard that there are specific diets for promoting bone healing. The important thing was a high calcium intake. You understand that your bone is made of calcium. If the bone has no materials to grow with.... then how can it possibly rebuild.
Here jimmy these two pieces of metal broke, weld them back together, but jimmy you cant use any materials or a welder.... I would check with a physical therapist and see if they have a diet and work outs for you to try.
I would prefer physical therapy and put myself through absorbent amounts of pain everyday before a plate. Why? Because your in control of the pain everyday and that makes it 1000000 times more manageable then dealing with pain you didn't create from a plate.
I do hope you heal ok.
1987 Harley-Davidson Sportster 883 conversion 1250. Python 3 exhaust, S&S super E Carb, Ported and polished heads, Ported intake manifold, ev3 Cams, Dunlop 401 F, Dunlop K591 Rear, Dual disc front brakes, Progressive front springs, Rear 401 springs/shocks.
