0 Who Runs Turn Signals?
Last Post: vagrant318
Last Post: Martysf
0 Slip on muffler
Last Post: Tucsonmax1
0 New From CA
0 FNG from OKC
0 New in NM
0 Stage 1 results
Last Post: 09Nightsterrider
0 Need advice (Falters When Turning Corners)
Last Post: Krjrcustom1
0 Spokes or Mags
0 -75 ironhead, My first HD
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
Old 1st November 2007
CosmoTG's Avatar
CosmoTG CosmoTG is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Kawasaki Vulcan 1500
CosmoTG is an unknown quantity at this point
Default Head Bolts
I am gathering parts for re-assembly of my bike and was wondering if I should buy new head bolts? Secondly is it a good or bad idea to use anti seize compound on them?...Leaving no stone unturned, Cosmo
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 2008
Other Motorcycle Model: XLRTT
Hi CosmoTG,
Reuse them and put a dollop of anti disc brake seize/copper grease on them...
Patrick
Flat Head Forever
Old 2nd November 2007
Question
Originally Posted by thefrenchowl View Post
... Reuse them and put a dollop of anti disc brake seize/copper grease on them ...
This is because the difference between regular anti-seize and anti disc brake seize/copper grease is: ?????
CosmoTG's Avatar
I was wondering the same thing...and how much is a dollop? ...Cosmo
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
The copper based anti-seize is often used for spark plug applications and can withstand high temps. But, I just went to McMaster-Carr's website and they list all sorts of anti-seize lubricants, copper based, aluminum, stainless, nickel, lead, etc. and pretty much all of them have high temp capability. I'd imagine any anti-seize compound would work on headbolts. I usually smear enough to give a light coating to about half of the bolt threads, figuring it will work its way into all the threads as the bolt is tightened. You don't have to overdo it.
Eric
OutlawTexan67's Avatar
OutlawTexan67 OutlawTexan67 is offline
Other Motorcycle Model: FXDBi Street Bob
Other Motorcycle Year: 2007
OutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura about
I use an aluminum based anti-sieze because as everyone knows aluminum transfers heat very well and I have found it doesnt dry up as quick as for example a copper based .But like Eric they all can with stand Hi temps.
Ain't No Head Like an Ironhead !!!!!!!
Chris
http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=13392 My Gallery
http://outlaws-iguana-ranch.com Outlaws Website
http://i258.photobucket.com/albums/hh266/OutlawTexan67/My%20Ironhead/Gifs/BigRotatingSkull.gif "Ironhead Mafia" European Chapter
