Last Post: Moon Wolf
Last Post: kaveebee
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: Beelzeboss
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Last Post: maltesefalcon
Old 30th January 2011
BrentmanII's Avatar
BrentmanII BrentmanII is offline
Sportster/Buell Model: XLH Old School
Sportster/Buell Year: 1982
Other Motorcycle Model: Dyna SuperGlide Custom
Other Motorcycle Year: 2008
BrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of lightBrentmanII is a glorious beacon of light
Default Using CLR ( acid ) to clean ( light ) rust from gas tank?
Ok now..... I have read the post in XL Forums about cleaning gas tanks.
The tank I have just has light rust ...no heavy scale. So I wondered if I needed to give it a rinse with acid/water and marbles?...or just leave it alone...and put a good filter on the line!
( maybe give a rinse with solvent and give it a good blow job!!! being careful not to get solvent on the lips .. ha ha ha!)
My past mechanical experience with any type of acid...is as soon as it touches metal....and you clean it off..... the metal rust before your eyes...I'm thinkin that the tank would do the same.
patrickd's Avatar
patrickd patrickd is offline
Sportster/Buell Model: XLX
Sportster/Buell Model #2: XL1200Low
Other Motorcycle Model: Kawasaki ZZR1200
patrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nicepatrickd is just really nice
I know of many people who have used a product called "The Works" Toilet bowl cleaner to rinse light rust out of the tanks. It's cheap and you can get it at WalMart. Probably about the same as CLR, but if you already have a bottle of CLR use it. It will disolve light rust just as well. Make sure to oil the tank after you rinse the shit out of it or it will flash rust pretty quickly.
A way to prevent tank rust is when you put the bike in storage for the winter fill the tank with 2 cycle gas. The oil in the gas keeps the rust down.
The procedure in the FM to store a fuel tank is to put in a small amount of 50/50 oil/gas mix, slosh it around, and empty the excess. You need only a few ounces of each. The gas evaporates and leaves the oil behind. Trying to do this with straight oil is difficult.
I have used the CLR with no success, but it was in a tank with heavier rust.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
I've always used diluted muriatic acid. Then rinsed it thoroughly with hot water. Used a hair dryer on high to dry it thoroughly (takes about 45-60 minutes with the nozzle stuck in the gas opening). Then immediately use Micks tip with 50/50 oil and gas.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
PetesPonies PetesPonies is offline
Sportster/Buell Year: '59
Sportster/Buell Model #2: 2004 XL1200R
Other Motorcycle Model: 2004 XL883 '57 Tribute
PetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud of
Phosphoric acid ( easy to find) will remove the rust inside the tank.
Pete's Ponies Mustang RUSToration & Performance
Sportster/Buell Year: 1972
Or if you don't want to handle acid, have a radiator shop remove the rust.
Old 31st January 2011
and have them install a RedKote or POR [not Kreme] tank liner.
nikki's Avatar
nikki nikki is offline
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
or use coke cola as it is high in Phosphoric acid ,but the suger in the cola will messup the motor Nikki
the difficult can be done immediatey the impossible takes a little longer
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
If you're not in a rush, and want the inside of your tank as claen as the day it left the factory, fill it completely with a 50/50 mix of molasses and water. Depending on how rusty it is, it can take from 1 month to 6 months, but it won't eat any of the "good" metal away and it wont harm the paint.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
nikki's Avatar
rivethog drop a rutsy bolt in a coke and watch the rust convert to iron phosfate . it's an old paint shop trick from the fiftys. Nikki
