Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 2nd February 2011
IronheadMatt IronheadMatt is offline
Sportster/Buell Model: 79xlh
IronheadMatt is an unknown quantity at this point
Default Help
Help i was doing some work to my topend today and accidentally dropped a cylinder base nut into the crankcase.The motor is out of the bike and on a workbench is there anyway i can get the nut out without splitting the cases any ideas or input would be greatly appreciated
oldnavy's Avatar
oldnavy oldnavy is offline
Sportster/Buell Year: 1972
Other Motorcycle Model: FXRS Low Rider
Other Motorcycle Year: 1986
oldnavy is on a distinguished roadoldnavy is on a distinguished roadoldnavy is on a distinguished road
If you have the jugs off, get an extended magnet and fish around. You may be able to turn the engine upside down and shake it loose and out.
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
exactly what he said , if you have to split the cases do it right and measure tolerences and do a full rebuild
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
dr.feltersnatch's Avatar
dr.feltersnatch dr.feltersnatch is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 08
Sportster/Buell Model #2: Xlh
Sportster/Buell Year #2: 77
dr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud of
Get a super strong magnet on a string or a stick and fish for it. Try turning it upside down and blow some compressed air in there and see if it will rattle loose. just take your time and you will get it.
"A man dies when he does not stand up for what he knows is right"
DR DICK's Avatar
DR DICK DR DICK is offline
ok what did i miss? turn motor upside and shake. no?
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Yeah, use the magnet trick tho' I'm not sure I'd use a magnet on a string. Too likely to also lose the magnet.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
You need to fish with a magnet on something stiffer than a string. A magnet on a string will go straight for the flywheels every time you lower it into the crankcase. Before you fish for the nut, a mechanic's mirror might be handy to possibly see where it went.
Old 3rd February 2011
XLFREAK XLFREAK is offline
Prop it upside down on some wood blocks and rotate the flywheels. There are lots of places where the clearances are too close for the nut to pass through, so you are hoping to get the nut to go between the flywheels. It make take some time.
jonnybravo jonnybravo is offline
Banned
Sportster/Buell Model: Ironhead Chopper
Sportster/Buell Year: 84
Other Motorcycle Model: Kaw Z1 900
Other Motorcycle Year: 1973
jonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura about
they sell magnet on a flexible stem for this purpose at any auto parts store
I also once took a shop vac and a piece of clear hose, duck taped it to the end of the nozzle to vacum crap out, might also work for this
SCchopper SCchopper is offline
Banned
Sportster/Buell Year: 1979
SCchopper is an unknown quantity at this point
Get the smallest shop vac fitting and stretch something like pantyhose over the end, trim the excess hosery and rubberband it to the vacuums fitting. Then, get a couple of buddies to hold the engine and while rotating toward as you fish it out with the suction. The pantyhose will prevent it from going up the vacuum hose. You can use any vacuum, but shop vacs are stronger and don't really require the "hosery screening", as long as you're willing to pull it from the mucky tank. If you had a larger sorta clear flexible hose you could duct tape that to an open vacuum hose and get it from anywhere.
Not all bolts are ferrous? A magnet may not always work?
