Last Post: David L.
Last Post: Naplesron
Last Post: Grumpy-Biker
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
883, converstion, performance
Old 7th February 2011
01norcalsporty 01norcalsporty is offline
Sportster/Buell Model: XL
01norcalsporty is an unknown quantity at this point
Originally Posted by ttopbandit View Post
My 883 hangs "just fine" with my buddy's 1200 S, that is, until we get to the upper end of 5th, the he starts pulling on me. Mine? A 98 883 Hugger, with a Screamin Eagle 1200 pistons and jugs, stock heads and cams. Add my screamin eagle exhaust and she scoots fine. The gearing helps alot, but I am thinkin about changin pulleys for mor highway...maybe....
How many teeth are you considering going up and on which pully? I understand you can change either the sprocket on the output of the motor or the pully/sprocket on the rear wheel.
Old 20th February 2011
camcarvin's Avatar
camcarvin camcarvin is offline
camcarvin is on a distinguished roadcamcarvin is on a distinguished roadcamcarvin is on a distinguished roadcamcarvin is on a distinguished roadcamcarvin is on a distinguished road
No way hes doin 140 mph with his 1250 build if hes runnin the 28 tooth 883 pulley !
Flamin883's Avatar
Flamin883 Flamin883 is offline
Sportster/Buell Year: 94
Sportster/Buell Model #2: 1200C
Sportster/Buell Year #2: 03
Flamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura aboutFlamin883 has a spectacular aura about
One thing that no one has mentioned, is the fact that you can actually have a better preforming longer lasting engine after the upgrade if you have it done correctly. all the OEM parts meet the factory specs and are just pulled from a bin, so it is possible that you end up with a rear jug on the outer/upper limit of specs a rear piston on the lower end of spec. while the front is exactly the opposite so you end up with kinde of a missmatch. but when you have a quality shop set things up for you you can come out with exactly .002 clearance on both. same goes with the chambers of the heads there can and probably will be slight differances, but I know both of mine are just shy of 56 cc's and identical, this makes for a much smoother running engine I still run the 883 gearing and can see out of the mirrors at 85+ in 4th gear. But it's not anywhere near a fair comparison to a stck 1200
Kyle
94 Flamin 883
9.5-1 1200 flat tops under Flow Tech worked 883 heads
SE ac, SE bolt in cams
CS tapered cut exhaust
Old 17th March 2011
Scrapper's Avatar
Scrapper Scrapper is offline
Scrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of light
The stock 883 crank shaft has a lighter balance weight on it due to the smaller 883 pistons so 883 conversion pistons are normally lighter than stock 1200 pistons(as well as having a reverse dome for dropping compression)
So technically an 883 /1200 conversion should spin up faster and have better throttle response than a stock 1200.
Now this is where people fall down,
Not installing bigger 1200 sized valves.
Installing 1200 heads and normal 1200 weighted pistons in an 883 bottom end.
And as mentioned the gearing of your front pulley is 1 tooth smaller in the 883 which will hurt you on the highway against your 1200 buddy.
hopes this makes some sense.
stage 1 nightster 79 hp 81 ft/lb
Old 17th March 2011
Big_Baazzoo's Avatar
Big_Baazzoo Big_Baazzoo is offline
Bike Builder
Sportster/Buell Model: XLH Lo 1200 conv.
Sportster/Buell Year: 1989
Big_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really nice
yeah, it's that front pulley that needs changing.
http://img48.imageshack.us/img48/2952/bettyandbuddysigql4.jpg Ride Free!
Old 17th March 2011
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
No it doesn't. The Motor Co went to a common flywheel assembly in the mid 90's.
Old 17th March 2011
Scrapper's Avatar
I stand corrected so is that why the new 1200s vibrate like hell, is the crank balance factor matched for 883s ?
Old 17th March 2011
Default Vibrate Like Hell?
Scrapper,
Mine does not vibrate that bad at all. Unless you compared it to a ricer, which I am not.
When looking I checked out the non-rubbermounts.
Maybe you are seeing bad tunes?
Old 17th March 2011
Scrapper's Avatar
Compare it to a new 883 they vibrate, unless somehow magically HD have managed to perfectly split the difference with their common flywheel assy.
Old 17th March 2011
Default Smaller Can Be Better
Lots of good things to say about the 883, now that is one of them that I did not know.
