0 C.O.B.B run west
Last Post: pdavis5160
0 XL flywheel
Last Post: Dmac
Last Post: Heff
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: 72 Ironhead XLH
0 Shovelhead forum gone?
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: SKID LID
Last Post: 60weight
Last Post: Tucsonmax1
Old 5th February 2011
Yanceman Yanceman is offline
Yanceman is an unknown quantity at this point
Default Drag Pipes
My ride is a 2001 XLH1200 and I want to put on 2 inch diameter drag pipes. I have installed forward controls. My question is do I have to buy pipes designed for a 1200 custom or the standard?
Banned
I believe 1 3/4ths pipes will make your bike run much better for a street bike.
unfiguroutable's Avatar
unfiguroutable unfiguroutable is offline
Sportster/Buell Model: XL883L
unfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the rough
1.75 inner and 2.0 outer are the same size..right?
LoyaltyRB
mycle1000 mycle1000 is offline
Sportster/Buell Model: xlx61
Sportster/Buell Year: 85
Other Motorcycle Model: yamaha vstar 650 custom
Other Motorcycle Year: 00
mycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to behold
no. both dimensions are outer.
85 xlx61 (with a million miles and a million mods)
05 xl1200r (bought used)
00 vstar650 (for the wife)
Default hmm
ok then my bike comes stock with 1.75 inch pipes...good to know..though I have already replaced all that
ian03xl's Avatar
ian03xl ian03xl is offline
Sportster/Buell Model: 883>1250 hugger
Sportster/Buell Model #2: xb12 supper TT
Other Motorcycle Model: can-am renegade 800
Other Motorcycle Year: 2007
ian03xl is on a distinguished roadian03xl is on a distinguished roadian03xl is on a distinguished road
To answer your question it doesn't matter what model sportster as long as the year listed matches the year of your bike. I know some years are different than others but engine size and model make no difference with exception to the xr1200. someone can correct me if I'm wrong.
nrhs 1250 jugs and pistons 10.5:1 cr, thunderstorm heads, andrews n4 cams, dyna 2000i ignition, se aircleaner, VanKirk 2-1 exhaust, and ohlins rear shocks
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Well, your partly right. As long as the pipes say they will fit with forward controls you'll be good to go. As far as the year goes, pretty much any will fit that are for the years 1986-2003. But as ASONTV says, straight drags at 2" diameter is going to run like crap at low and mid range RPM. Unless your going to run at wide out throttle all the time (the drag strip) your much better off going with another pipe. Drag pipes are for the drag strip.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
ian03xl's Avatar
You are correct sir I forgot to mention the forwards. And by year I just meant anything newer than 03 will not necessarily fit. I will also testify (as will almost everyone else on this forum) that drag pipes do not perform well on the street and they're only good for making a lot of noise.
Old 6th February 2011
noise, obnoxious noise is what some people consider performance.
shotgun46's Avatar
Here we go again Drag pipes will work and do not have to be loud and obnoxious ! and use the 1.75 pipes and then read this to help tune it properly and I can Provide a Dyno sheet that says you can tune it properly
http://www.nightrider.com/biketech/exhaust.htm
