Ei
Last Post: trappnman
Oil??
1Scooter (68), wallylach (67), cob (64), decman (62), djhannu (56), Vaughn, irishhog (49), dangjalopy (45), earthoverdrive (40), edman87k5 (39), 79iron (36), mr_anti_chrome |
7th February 2011
Posts: 195 Sportster/Buell Model: Ironhead XLH Sportster/Buell Year: 1971
Help With Wiring (Diagram)
Hi all-
I took a picture of most of my components, and I wired it up to how I think it should go according to the plethora of diagrams I found in the stickis.
Questions:
1) Do I have it wired up correctly?
2) Are the colors correct for the wires?
3) For the coil, how do I know which one is the -ve and which end is the +ve? The one in the picture is mine, and it doesnt have any markings.
4) I'm using the special gauge wires for the battery terminals and standard gauge for everything else - does the Solenoid to Starter wire include this?
5) I'm not using a key - just a start button and an on/off switch. Its hard to see from here but the switch is in the off position in the picture (pointing down). Is that wired right?
I realize this is only for the starting and charging portion of the wiring. I havent put any blinkers or lights on the bike yet.
Thanks!
-Max
7th February 2011
Posts: 8,955 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
#2. it really doesn't matter what colors you use, as long as you know what is what.
#3. the coil is universal. it doesn't matter which side gets the +12. typically the points or ei connect to the right side when it's mounted on the bike simply because the points are on the right.
when you say "standard gauge for everything else" what gauges are you using specifically? it's important to have the proper wire gauges...
as for the rest someone else better versed in electric start will have better answers for the rest of your questions.
caution! do not stop on tracks.
7th February 2011
Posts: 3,065 Sportster/Buell Model: XLCH Sportster/Buell Year: 1971 Other Motorcycle Model: FXDL Other Motorcycle Year: 2003
Your starter wiring looks OK as long as the wire (shown red) going from the battery + post to the solenoid connects to the longest stud on the solenoid.
The shorter stud on the solenoid connects to the starter motor.
Then after all the wires are connected to the machine and before you start it be sure to 'flash the field'. Then start the engine.
pg
7th February 2011
Piniongear -
I did indeed mix up the two posts for the solenoid - the top one is the longest and should go to the bat.
Did you mean all of the wiring looks good in the diag, or just the Solenoid / Starter bit?
I was reading through the instructions for polarizing the generator - I think I have it down.
Thanks
Max
7th February 2011
Originally Posted by Maxxra
Piniongear -
Thanks
Max
I think you have all the wiring correct.
The only comment I can make is if you have a 1971 model, I believe it did not come equipped with a starter relay.
I could be mistaken of course.
Looking at a diagram of a 1971, the starter circuit is as follows....... beginning at the ignition switch terminal 'I'
1) Orange wire runs to a fork terminal board.
2) Off this terminal a white wire runs to the push button starter switch.
3) Off the switch a black wire runs to the fork terminal board (a different terminal than item 2)
4) Off this terminal a black wire runs to the small connection on the solenoid. No relay is used.
Now, to use a starter relay the relay is inserted in the black wire in item 4. The relay gets it's power from the battery. This would be a red wire coming from the regulator or at least downstream of the overload circuit breaker.
I think you have everything wired correctly.
pg
7th February 2011
Posts: 31,160 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
Originally Posted by doodah man
... when you say "standard gauge for everything else" what gauges are you using specifically? it's important to have the proper wire gauges ...
+1 here. Confirm what gauges you used.
7th February 2011
You should add a 15 amp circuit breaker in both the light and run circuits as 30A is too high to protect the smaller wires.
The reason for using 2 15A breakers is so that the light circuit can't take down the run circuit.
7th February 2011
Mick & Doodah Man-
I'm going to be using 16 gauge automotive wiring - I was told that was the standard?
Thats going to be for everything EXCEPT the battery terminals and the wiring from the solenoid to the starter.
Piniongear -
Thanks for looking it over! I really appreciate it!
I updated the diagram with corrections you pointed out for the solenoid to starter, Pinion.
7th February 2011
Posts: 2,463 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972 Other Motorcycle Model: Heritage Softail Other Motorcycle Year: 1999
16 gauge is fine. I doubled up 2 16 gauge wires for battery cables and encased in shrink with appropriately sized ring terminals. No electric start to mess with.
7th February 2011
Picky time ... the cable from battery +ve to the solenoid would usually be black.
