0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
0 surges and/or hunting on 1200 EFI's
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
0 Iree's jukbox joint
0 900 heads contd..
Last Post: spacecoast
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Old 11th February 2011
joey81iron85 joey81iron85 is offline
Sportster/Buell Year: 1981
joey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the rough
Default exhaust heat wrap question
im wanting to wrap my drag pipes with this stuff can some1 tell me how much i need to buy 25' 50' and do i need to buy the spray adhesive stuff and spray pipes before i wrap thanks
snowman's Avatar
snowman snowman is offline
I use about 5x the actual length of what I'm wrapping.
I have never seen any adhesive, just silicone spray to keep the wrap pliable...
What kind of pipes are you covering???
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
sportsterpaul sportsterpaul is online now
Something else to consider, if you wrap the pipes from the back to the front they tend to collect less dirt and debris. F.W.I.W.
avl8386 avl8386 is offline
Sportster/Buell Year: 1966
avl8386 is an unknown quantity at this point
I saw a tip on biker build off to soak the wrap in water for a few hours and then put it on while feeding it out of the bucket. It keeps the graphite or whatever is in it from making you itch and makes it wrap tighter when it dries
Joesdaddy's Avatar
Joesdaddy Joesdaddy is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: '83
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: '85
Joesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of lightJoesdaddy is a glorious beacon of light
My son just did some wrap on his with a 15' roll. It was just enough to do both pipes just past the bends. I think he used 8' on the back and the other 7' on the front. Just soak it a couple minutes in water, wrap and zip-tie ( the wider zips work best), let it dry overnight and spray it with the DEI silicon spray. It will smoke and stink a little when your fire it up.
Ivan RoachCoach's Avatar
Banned
Default WEAR GLOVES! A buddy of mine rattle-canned...
...the pipes first to keep them from rusting through under the wrap.
Something to consider.
...It keeps the graphite or whatever is in it...
Fiberglass. In a previous life I built fiberglass boats. You learned all sorts of tricks to stay away from the stuff. Like IRC said, physical barriers are a good choice - gloves, long sleeves, etc. When we had to grind surfaces with a side-arm grinder, we would suit up like we were doing HAZMAT work... If you get it on you rinse it off; don't rub, as that will push it into the skin, not off. If it does get embedded in the skin, scrubbing the affected area with a a stiff brush does a pretty good job at dislodging the glass fibers. Itchy stuff...
kowboi kowboi is offline
kowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura about
It should tell you on the package how to measure for the wrap. You have to allow quite a bit more for bends than you do for the straight sections.
Maxxra Maxxra is offline
Sportster/Buell Model: Ironhead XLH
Sportster/Buell Year: 1971
Maxxra is on a distinguished roadMaxxra is on a distinguished road
+1. I wrapped my pipes last weekend barehanded. I am a dumb@ss.
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
If you soak them in water, it makes wrapping easier and tighter. i've done many of them and I go from back to front with a 1/4 to 3/8 lap. No gloves, no spray, and use stainless wire as ties-cheap at the hardware store. And the nice thing about getting it wet is after it dries, it shrinks and wraps really tight!
Life may begin at 30, but it really interesting around 150!
